clutch
What does it mean it when i release the clutch it squeaks and if I do it slowly you can feel like something is not lubricated and is "squeaking" (the peddle does not release smoothly).
Probably your T.O. bearing or slave cylinder, simply adding more grease will fix the problem until the grease dissapears again.
Also check your clutch master cylinder, dirty fluid can clog the lines.
nsimov
Nov 28, 2005 08:04 PM
