Cluster problems
Old Jun 5, 2010 | 03:11 PM
tweatybird74's Avatar
Default Cluster problems
I have a UK cluster in my 2000 PYT ITR that reads 260km
when i start the car the engine temp goes to hot and the fuel gauge goes to full. further more the Tach does not work unless the headlights are on and when i put my indicators on left or right the Tach will bounce up and down. The actual speedo works fine as well as all other dash icons. can someone shed some light on this. does this have anything to do with having my crank sensor not working
Old Jun 5, 2010 | 06:55 PM
milkmanLCA's Avatar
Default Re: PLEASE HELP - CLUSTER PROBLEMS
sounds like your cluster wires are pinched along with your lights
Old Jun 6, 2010 | 08:04 AM
how would i go about fixing that ????
Old Jun 6, 2010 | 08:22 AM
milkmanLCA's Avatar
go through all your wiring, and see if any are showing bare wire. ensure all is wrapped securely
Old Jun 6, 2010 | 08:33 AM
are you talking about the wiring hraness connecting to the back of the dash ??
Old Jun 6, 2010 | 10:02 AM
94rs-turbo's Avatar
was anything else modified? was the stock cluster working perfectly before you put in the eudm cluster?if thats the case swap out the rear green film from the stock usdm cluster with the eudm one and plug it back in
Old Jun 6, 2010 | 08:07 PM
Dave-ROR's Avatar
Sounds like a different cluster installed in the car? or is it original? If it's not original, the year is likely different, and the wiring is different. you can either swap the green film like 94rs said, or swap the gauges themselves (since I'm assuming that's why you swapped clusters if you did) into your original cluster housing, both methods will fix the issue.
Old Jun 7, 2010 | 10:26 AM
Everything was working on my stock cluster except for when i hit vtec the rpm gauge would cut out but i think that is because i dont have my crank sensor hooked up and thats what it feeds off of
Old Jun 7, 2010 | 12:35 PM
Dave-ROR's Avatar
Ok well the solution(s) is already posted, so do that and it should be fine.
BlackJacket
Nov 24, 2013 02:06 PM
Ryan.
Oct 30, 2007 06:46 AM
jfoster
Nov 13, 2005 04:46 AM
VTECth1s
Nov 6, 2005 06:51 PM
E-lude78
Jun 5, 2003 01:20 PM
