Checking Routine not functioning?
Old Jun 21, 2005 | 04:06 PM
Squid Squad's Avatar
Default Ignition Checking Routine not functioning
Hello everyone, I'm so glad to find this forum.
I have a 1998 ITR and always thought I'm the only one out there
I have a quick question and would appreciate if someone can help me with it.
When you start up the car, as you put your key to Stage II of the ignition, battery will come on and various check lights. It's suppose to make a "beeping" sound and I usually wait for it to stop before cranking the engine.
The car came with a cheap alarm and recently starts to act funny, such as unarm itself after I arm it, or siren starts while I'm driving...and that's the around the time the check routine stopped, only a few lights come on and no beeping sounds.
I uninstalled the alarm and it's still not performing the check.
I'm worried about it and would like to know if anyone have similar problems, is it a short? if so, where should I look? Is it a blown fuse? If so, which one?
Thanks in advance for any comments.
Modified by Squid Squad at 5:17 PM 6/21/2005
Old Jun 21, 2005 | 04:19 PM
Chris F's Avatar
Default Re: Checking Routine not functioning? (Squid Squad)
Can you hear the fuel pump prime as you turn the key to position 2? I noticed that mine did not, when the alarm was armed and ignition cut was working, and some other weird things too like the doors didn't lock themselves until the alarm was off.
Does it beep if you open the door and turn the lights on?
It could be just the beep is gone.
Do you get the ABS, Check Engine and battery lights at least?
Old Jun 21, 2005 | 06:08 PM
Default Re: Checking Routine not functioning? (Chris F)
Nope, I do not hear the fuel pump engage.
The check engine light, ABS light do come on and off.
Have you found the remedy?
Old Jun 21, 2005 | 06:18 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Squid Squad &raquo;</TD></TR><TR><TD CLASS="quote">Nope, I do not hear the fuel pump engage.
Have you found the remedy?</TD></TR></TABLE>
Disable the alarm.
Sorry that isn't much help.
Old Jun 21, 2005 | 06:40 PM
Mythias's Avatar
Default Re: Ignition Checking Routine not functioning (Squid Squad)
Get out the volt meter and start checking for shorts.
Old Jun 21, 2005 | 06:45 PM
Ed 341's Avatar
Default Re: Ignition Checking Routine not functioning (mythias)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mythias &raquo;</TD></TR><TR><TD CLASS="quote">Get out the volt meter and start checking for shorts.</TD></TR></TABLE>
Old Jun 21, 2005 | 07:19 PM
Default Re: Ignition Checking Routine not functioning (itr341)
I did once with a borrowed multimeter, at the fuse box beneath the steering column, all hit 12v. And I don't trust ppl to bring it to a shop to check the electric.
The Alarm is already out
M3Stylz
Dec 14, 2007 05:30 PM
eJDMb16a
10
Nov 29, 2006 07:21 PM
comteg396
Audio / Security / Video
Dec 8, 2005 10:59 PM
mehdiR
Aug 29, 2005 07:43 AM
crxaddikt
Sep 23, 2003 02:46 PM
