check engine light guide
Old Apr 4, 2003 | 05:11 PM
01-0720's Avatar
Default check engine light guide
archived searching is disabled right now , does anybody have a guide to what all the check engine codes are and what they mean
and how to check the codes on a 01 itr
i thought there was a plug near the ecu that you took a paper clip adn closed the cicuitr but i coulnt find the plug
to anybody that can help
Old Apr 4, 2003 | 05:57 PM
fowler!'s Avatar
Default Re: check engine light guide (01-0720)
Dude, search!
http://hybrid2.honda-perf.org/tech/codes.html
Check C-Speeds faq for instructions on how to pull a code.
Old Apr 4, 2003 | 06:45 PM
Asahi's Avatar
Default Re: check engine light guide (fowler)
http://www.itrca.com/FAQ/troubleshooting/celcodes.php
Old Apr 4, 2003 | 06:46 PM
BRICKHEAD's Avatar
Sometimes your car will throw what is called a false code. Sometimes this will happen when accelerating hard into a turn or for many other reasons. As all of you know the car goes into limp mode when the " Check Engine " light comes on. Now we all know that light sucks so if you want it off all you have to do is go under the hood to your fuse box and pull the 7.5 amp radio fuse. This fuse controlls radio memory and ecu memory. Pull the fuse for about 5 to 10 minutes, do not drive or start the car while fuse is out. When the time is up you must put the fuse back in and reset all your radio stations and interior clock but I assure you that light will be off. Not a lot of people know about this so I thought I would pass it on to fellow Honda Tech'ers. It is not a permenant solution but it will turn the light out until you can troubleshoot your problem. Hope this helps some people.
[Modified by BRICKHEAD, 7:47 PM 4/4/2003]
JDMJUNKIEMONKIE
Oct 22, 2009 09:24 PM
NewEra
Jul 20, 2009 08:13 PM
str8JDMteggy
Sep 24, 2006 08:42 AM
SmogKing
Aug 3, 2006 12:48 PM
urgonnalearn2
Oct 20, 2003 11:54 PM
