carbing inside -->
Old Mar 5, 2003 | 12:19 PM
austrian type-R's Avatar
Default carbing inside -->
man, I have absolutly no more space in that engine bay
Old Mar 5, 2003 | 12:20 PM
jonas's Avatar
Default Re: carbing inside --> (austrian type-R)
simple green is your homie.
Old Mar 5, 2003 | 12:21 PM
RaVAGE00's Avatar
New User
Default Re: carbing inside --> (jonas)
yeah. clean that bitch!
Old Mar 5, 2003 | 12:22 PM
Chris N's Avatar
Default Re: carbing inside --> (RaVAGE00)
Nice looking bar Christian.
Why clean the engine bay??
It ain't no' show car.
Chris - who's engine bay is dirtier
Old Mar 5, 2003 | 12:32 PM
ITRinEJ1's Avatar
Default Re: carbing inside --> (Chris N)
lots of bling in there fo fizzle
Old Mar 5, 2003 | 12:33 PM
jonas's Avatar
then why show off the strut bar
Old Mar 5, 2003 | 12:34 PM
RaVAGE00's Avatar
New User
Then why wash the car at all???
Old Mar 5, 2003 | 12:37 PM
Eva01's Avatar
Because it reduces flex of the chassis. It's functional but also carries a bling factor. Not the other way round.
Old Mar 5, 2003 | 12:38 PM
Chris N's Avatar
I'm just kidding around....
Old Mar 5, 2003 | 12:39 PM
itr-j's Avatar
how much bling did that cost you
Old Mar 5, 2003 | 12:40 PM
SamB's Avatar
New User
Default Re: carbing inside --> (Eva01)
looks good
Is it actually bolted to the firewall??
Old Mar 5, 2003 | 12:41 PM
Chris N's Avatar
Default Re: carbing inside --> (SamB)
looks good
It looks like it may be.
When I saw sack's bar at Gingerman last October, I don't think his was bolted to the firewall....
Old Mar 5, 2003 | 12:43 PM
jonas's Avatar
looks good
the bar is designed too. and judging from the pic, i see the two 10mm bolts there.
hehe, why washing the engine bay? Nobody see it except you guys The car must drive and that as fast as possible, durt is not robing me horses Yeah, it is mounted to the firewall as well. I mounted the MAP sensor on the little bar where it is mounted to the firewall. hehe.
[Modified by austrian type-R, 10:44 PM 3/5/2003]
Old Mar 5, 2003 | 12:46 PM
jonas's Avatar
any reason for that? i dont suppose its because the bar is an issue, because my carbing cleared it by far.
Old Mar 5, 2003 | 12:52 PM
I have a aftermarket GM 3 Bar Map Sensor. It was mounted on the firewall, but the bar goes into that place now. I need the 3 Bar MAP for my Haltech e6k standalone.
Old Mar 5, 2003 | 01:28 PM
Hooch'n's Avatar
nice and clean............hahaha
Old Mar 8, 2003 | 07:55 PM
ppihctyper's Avatar
If a chain is a strong as a weakest link how strong are two 6mm (10 mm head) bolts attached to a firewall?
I really like the concept, however, despite the large contact surface with the firewall, I wonder if a better mounting design could have been established on the firewall?
Do you have a close up photo of the firewall interface?
[Modified by ppihctyper, 4:56 AM 3/9/2003]
Old Mar 8, 2003 | 09:23 PM
sil's Avatar
sil
Default Re: carbing inside --> (ppihctyper)
hrmm.. i'm not sure about this one.. but lemme have a chime at it..most of the chassis flex will come from a side to side motion.. in other words the shock towers will try and flex towards each other... if that's the case, then at each shock point, you're bracing it 1) to the other tower, and 2nd to the firewall..it's because of the large contact surface that basically keeps the shock tower from flexing .. my guess is that if the angle towards the firewall were too small and the contact surface was also too small, then basically any sideways motion (a lot of it) would try and sheer off the bolt, so yes that would be the weakest link.. however it looks to be a good enough surface area with a large enough angle that this would not happen, plus the fact that the shock towers probably don't move that much to begin with...now i would assume that if the firewall mount were in the centre and the angle towards the firewall were 45degrees (with a large enough contac surface to the firewall), that would be the 'ideal' position.. but that's not going to happen given all the crap mounted there.... excuse my ranting.. tired from trying to do an FD install in a typeR (stage 1 complete)..
Old Mar 9, 2003 | 01:38 AM
airon's Avatar
i like your overflow tank
Old Mar 9, 2003 | 01:57 AM
Default Re: carbing inside --> (airon)
hehe, yeah the cool red cap. It adds 3whp at least
Old Mar 9, 2003 | 03:18 AM
ahead's Avatar
i cant remember from the first post about this bar, but would i have to modify anything to make this bar fit on a 3rd gen gsr? and where did you get it from? thanks
Old Mar 9, 2003 | 05:16 AM
Default Re: carbing inside --> (ahead)
I got it from ITRinEJ1 , a great guy. HE has a groupbuy on that bar. Hit him an IM.
B00ST2nR
Apr 4, 2007 04:50 PM
hcivic99
Nov 15, 2004 09:14 PM
JDMlyfestyle
Nov 29, 2003 01:43 PM
skafia
Jun 17, 2003 02:03 PM
JLange
Jul 4, 2002 03:27 PM
