Cam Question
Old Feb 19, 2003 | 09:02 AM
MCP486's Avatar
Default Cam Question
For street use, I plan on using Skunk2 Stage 2 cams with CTR pistons. Why are the Stage 3's not practical for street use, other than a rough idle? I realize I won't pass emissions with them, but I can do a swap every 2 years.
Thanks,
Matt
Old Feb 19, 2003 | 09:13 AM
sgT's Avatar
sgT
Default Re: Cam Question (MCP486)
rough idle?? no. it should idle close to stock
Old Feb 19, 2003 | 09:16 AM
MCP486's Avatar
Default Re: Cam Question (sgT)
so would it be a good idea to put Stage 3's in a daily driver, that I plan on taking to the track every once in a while?
Matt
Old Feb 19, 2003 | 09:19 AM
sgT's Avatar
sgT
i dono. why wouldnt it be?
it all depends on if your motor can handle cams that big.
Old Feb 19, 2003 | 09:27 AM
MCP486's Avatar
When you say handle, you mean produce enough compression?
Thanks,
Matt
Old Feb 19, 2003 | 09:41 AM
ITRNoah's Avatar
you can use the stage three if you I think any thing is street able in my opinon the main factor is your power band is not going to be good for the street all your power is going to be in the realy hi Rs if you were to use these cams I would hope you have alot of tunning aids in your car cam gears pigy back/stand alone
Old Feb 19, 2003 | 09:46 AM
RiCE On IcE 2's Avatar
Default Re: Cam Question (ITRNaoh)
yea.. the stage 3 i think mess with ur idle but the bigger problem is that I think it's makes your low end power even worse, and you dun get the good stuff till the upper powerband but most street driving doesn't require us to be in the upper revs most of the time.
TomIntegraGSR
May 29, 2007 03:55 PM
NBPdEeCeE
Feb 2, 2007 05:14 AM
RP215.
Apr 23, 2006 12:52 AM
codeh22a4
14
Dec 9, 2004 04:32 PM
touge_dc2
Apr 6, 2004 05:03 PM
