A/C PROBLEM
Old Jul 29, 2008 | 01:26 PM
Ill Mitch's Avatar
Default A/C PROBLEM
well since the install of the Moogen intake, the suction line part of the a/c was rubbing on part of the car, (unknowingly to me obviously) well its hot as hell now, so i ordered the new suction line, question is, has anyone messed with a/c lines, and how hard is it to replace? looks simple, unscrew from both ends and replace??? its the line coming from the fire wall
# 28 in the diagram
Old Jul 29, 2008 | 02:05 PM
Comp97GSR's Avatar
Default Re: A/C PROBLEM (Ill Mitch)
It is simple, the hardest thing to do is remove the battery and tray... which is easy.
I told you to send that thing here so I could get you a custom flexible a/c line f00.
Modified by Comp97GSR at 5:27 PM 7/29/2008
totsie7944's Avatar
For starters make sure you get your AC evacuated first before you start pulling lines off. I believe you are correct however...after that you should be able to un-bolt them and replace. You may need some sort of thread sealer on them however. Anyone have better advice?
Old Jul 29, 2008 | 02:09 PM
ZygSpeed's Avatar
Default Re: A/C PROBLEM (totsie7944)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by totsie7944 &raquo;</TD></TR><TR><TD CLASS="quote">For starters make sure you get your AC evacuated first before you start pulling lines off. </TD></TR></TABLE>
My guess is that if it rubbed through and presently doesn't "work", that it's essentially already "evacuated".
Old Jul 29, 2008 | 02:33 PM
Ill Mitch's Avatar
Default Re: A/C PROBLEM (Zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
My guess is that if it rubbed through and presently doesn't "work", that it's essentially already "evacuated". </TD></TR></TABLE>
10-4 on that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">It is simple, the hardest thing to do is remove the battery and tray... which is easy.
Modified by Comp97GSR at 5:27 PM 7/29/2008</TD></TR></TABLE>
if this doesn't work, that is my next option
mugenr#1011's Avatar
yep nothing in the lines, ive had a similar problem with my mugen intake. mine were bent from a body shop, but the header burnt mine in front. ac w/ the mugen.
suxors, im good w/bolt ons but not with the lines. good luck
Tootsie7944
Oct 15, 2011 02:25 PM
93civic2005
Jan 14, 2007 01:18 AM
jvtec95
Aug 24, 2006 05:13 PM
Beave0101
Dec 18, 2002 06:54 PM
jthelman
Sep 11, 2002 01:49 AM
