A/C problem
Old Jul 24, 2005 | 10:13 AM
ITR184's Avatar
Default A/C problem
I got a little problem with the A/C. I replaced a timing belt and water pump 3k miles ago, and the drive belts looked to be Ok at the time. I did get a little coolant on the A/C belt while replacing the water pump. When I took it down the road the belt starting squealing at about 5k rpm with the a/c on (t was quite with it off) I tightened up and it was fine for about 2k miles. I was in a traffic jam not running the a/c and had the bottom bolt on the tensioner snap.
Today I put a new bolt on the tensioner, and put on a new belt. I set the tension with about 3/16" of play. Now I get the squeal at around 4.5k rpm. when I cruise around town it does fine, but as soon as I hit the autobahn it will squeal for a second then it wont do it again for about 15-20 seconds. I can also feel the engine surge. I am thinking that the compressor is locking up. That is the only thing that I can think of that would cause the bolt on the tensioner to snap.
91 b20 integra
Sep 22, 2014 08:44 AM
Tina Saunders
Jan 21, 2013 10:37 PM
trailshredder
Nov 1, 2010 07:11 AM
supracrx
Feb 17, 2008 09:06 AM
trevor72
Jun 7, 2006 09:55 AM
