busted stud
Old Apr 17, 2003 | 08:32 AM
98type_r's Avatar
New User
Default busted stud
broke a stud changing tires/brakes last week so now i'm running on 4 of 5 lugs.
Is this a DIY job, or would it be best left to the service dept to replace the stud?
Old Apr 17, 2003 | 08:33 AM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: busted stud (tie par)
Its DIY if you have the tools and mechanical abilities.
Old Apr 17, 2003 | 08:39 AM
Rob :190:'s Avatar
i'm a stud, and i'm broke...
shouldnt be a difficult job, you can probably do it!
Old Apr 17, 2003 | 08:41 AM
98type_r's Avatar
New User
Default Re: busted stud (Rguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rguy &raquo;</TD></TR><TR><TD CLASS="quote">Its DIY if you have the tools and mechanical abilities.</TD></TR></TABLE>
what would be the proper tools?
just hammer the busted one out and hammer a new one in? or would it be better to use a press to get them in/out?
Old Apr 17, 2003 | 08:53 AM
magic hat #9's Avatar
Default Re: busted stud (steve c)
steve, that is a hell of an avatar
Old Apr 17, 2003 | 08:56 AM
Nuts's Avatar
Default Re: busted stud (magic hat #9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">steve, that is a hell of an avatar </TD></TR></TABLE>
no kidding.
CS
Old Apr 17, 2003 | 09:57 AM
Trey's Avatar
25 Year Member
You don't have to take the knuckle off to get the new stud in.
Just use an air hammer and get the old stud out. Take the rotor off. Take the new stud, go to a bench grinder and shave off a flat spot on the back of the new stud. Now hammer it in from the rear (sounds bad). Put the rotor back on. Good to go.
Old Apr 17, 2003 | 10:00 AM
JDM CTR '00's Avatar
Default Re: busted stud (Trey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trey &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to take the knuckle off to get the new stud in.
Just use an air hammer and get the old stud out. Take the rotor off. Take the new stud, go to a bench grinder and shave off a flat spot on the back of the new stud. Now hammer it in from the rear (sounds bad). Put the rotor back on. Good to go. </TD></TR></TABLE>
That's what i did
Old Apr 17, 2003 | 11:56 AM
HogNutz's Avatar
do it yourself man its cheaper, plus if you have mechanical skillz then thats a even plus, cause it will take you 3 times as fast than being a rookie.
PirateTypeArgh
May 9, 2006 08:58 PM
Mooneyes13
Mar 2, 2006 10:07 PM
_Spugen_
Aug 5, 2005 05:43 PM
mrlegoman
Dec 1, 2004 09:42 AM
BlkGSR
May 3, 2003 08:16 PM
