bugger!! another VSS problem...
Old Dec 16, 2002 | 03:44 PM
baonest1's Avatar
Default bugger!! another VSS problem...
just pulled this from my JDM ITR vss.. i have 2 LS trannys that i was gonna swap, the gears are wider on the LS. hmm is the VSS even necessary
[Modified by baonest, 7:45 PM 12/16/2002]
Old Dec 16, 2002 | 04:02 PM
Austin's Avatar
Default Re: bugger!! another VSS problem... (baonest)
VSS is necessary for vtec to work...must be going faster than 13mph if I remember correctly...but my Hondata stage 2 kicks it in if I'm not even moving and the revs are above the vtec x-over.
Austin
Old Dec 16, 2002 | 04:15 PM
baonest1's Avatar
Default Re: bugger!! another VSS problem... (Austin)
thanx austin... damn. so now i gotta find a replacement.. are the JDM and USDM gears the same?? i checked out acura carland and couldnt find one. what is it called.. VSS gear??
Old Dec 17, 2002 | 08:21 AM
Austin's Avatar
try here http://www.acuraautomotiveparts.net/...catdisplay.jsp
Old Dec 17, 2002 | 02:01 PM
baonest1's Avatar
i actualyl found it earlier. it was under clutch bearing or somthing. around $28 is not bad i guess..
Old Dec 17, 2002 | 02:29 PM
Smitdog's Avatar
My VSS is faulty also, Speedo stops at 99mph no matter how fast I go. Been to lazy to replace it.
Old Dec 17, 2002 | 03:23 PM
FSTASNTZ's Avatar
Default Re: bugger!! another VSS problem... (Smitdog)
If you need a new VSS, I have one I bought and do not need. Part number 78410-st7-003. Let me know, still in the box...
Jason
abusedvtec
Dec 14, 2009 07:10 PM
Pnoyej6
Jan 17, 2007 05:50 PM
baonest1
Feb 1, 2003 10:41 AM
baonest1
Jan 31, 2003 07:04 PM
