Brake Light Switch Stopper Replacement?
Old Oct 10, 2009 | 08:44 PM
BlueIntegraBoy's Avatar
Default Brake Light Switch Stopper Replacement?
I was driving home today and felt something hit my left foot. I thought nothing of it until I had to remove the key from my car. Car was dead, and so I jump started it. Found out my plastic stopper on the brake pedal broke off causing my brake lights to remain on (which was the thing that hit my foot). Anyone know a good replacement? I was thinking a bolt and nut, but the head might be too thick. Any ideas?
Old Oct 11, 2009 | 06:44 AM
EM1 Loi's Avatar
Default Re: Brake Light Switch Stopper Replacement?
i have always used epoxy, jb weld, quick steel with a penny for an easy fix and never had it pop out on me. call me ghetto but it works...
Old Oct 11, 2009 | 10:10 AM
Devon M's Avatar
I just got a plug from a hardware store. A penny works, but I like the little black plug from the store better.
Old Jul 27, 2012 | 05:50 AM
matt56's Avatar
Hey sorry to bring up an old post, but what is the thing called that you got from the hardware store that worked as a brake pedal stopper pad? And what store? Mine broke and it would save me a lot of drive time to get this at lowes or something vs a honda dealership.
Old Jul 27, 2012 | 06:47 AM
90efb16's Avatar
You guys are cheap asses the part # is 46505-SA5-000. It only costs $2.27 go to your local dealer and buy it people
Old Jul 27, 2012 | 06:52 AM
matt56's Avatar
Ha ha, drive distance man! Lowes is 1/4 mile from me, Honda dealership is like 15.
Old Jul 27, 2012 | 07:15 AM
90efb16's Avatar
15 miles is a lot?? I drive more then that each day to work at a dealership
Old Jul 27, 2012 | 08:26 AM
94rs-turbo's Avatar
they must be affraid to put miles on their ITR
Old Jul 27, 2012 | 09:15 AM
matt56's Avatar
FYI for any do it your selfers, a nickel and a dime glued together is the perfect thickness to push the brake switch in, then you just glue the nickel side to the brake arm (I used loc-tite super glue for metal). No more problems with plastic pieces breaking, problem solved.
Old Jul 27, 2012 | 12:27 PM
90efb16's Avatar
Old Jul 27, 2012 | 01:12 PM
matt56's Avatar
Cost 15c, and no parts that will break ever again, not only cheap but smart :D
Old Jul 29, 2012 | 03:09 PM
verycleanhatch's Avatar
just use a bolt and a nut. problem solved. While your at it do that for the clutch stopper also.
Old Jul 29, 2012 | 03:51 PM
What an old post... I ended up using a carriage bolt. It will never break again.
Old Jul 29, 2012 | 05:06 PM
00-1065's Avatar
Old post but good info as that same thing happened to the clutch pedal on my R a couple of weeks back.
Old Apr 29, 2017 | 11:29 PM
mithridates's Avatar
I ran into this issue with my 99 Corolla. I used the dealership part, what they call a brake light switch cushion. The reason? The broken rubber switch cushion had an indentation from the brake light switch. If this switch cushion were metal, I imagine the indentation would be in the brake light switch. Brake light switches are more expensive to replace than switch cushions, both in terms of the parts cost and labor involved. Replacing the switch cushion involved starting the engine, pressing on the brake pedal with my left hand and pressing the switch cushion into place - in the notch provided - with my right hand in the 3/4" gap opened up between the switch cushion holder and the brake light switch. I don't even want to think about the amount of work involved in replacing the brake light switch.
Old May 19, 2021 | 05:48 PM
Werner Jauch's Avatar
Just in case it helps someone else, this happened me tonight, 2005 Honda Pilot, after auto parts stores closed. I cut a piece from a rubber eraser, left a prong stick out, pushed into the hole in brake pedal and used tape to secure it. Tomorrow I'll get the proper part.
Old May 26, 2021 | 10:40 AM
itrdave's Avatar
Nut and bolt makes a cheap, easy, lifetime fix for this
Xzay01
Lighting
Jun 14, 2013 08:53 AM
Nooch
16
Aug 28, 2011 01:05 PM
asocallocal
Aug 29, 2010 07:00 PM
gsrsuperman
13
Jul 21, 2008 10:20 AM
musclehead954
Feb 27, 2008 10:28 AM
