Blinking Oil Light
Hi, I was driving today and I noticed my oil light started blinking. I pulled over, and checked the dipstick to find it empty. Of course then I added oil and the light doesn't come on, but what would cause my oil to empty out like that? I changed the oil a while ago so I don't think it's due to a loose drain plug or filter.
Any help would be appreciated...
What he said. High revving engines do burn oil
http://www.speedvision.com/pub/artic...1/010822a.html
Only problem is that I don't have a Type-R, just a LS. I post in the ITR forum because alot of knowledgeable people are here so I just need to find out what's wrong.
I have 96k on the car, and I went through 4 quarts in little more than half a year. The only thing that has happned to my car recently is a severe overheating due to a cracked radiator. Could that have damaged some gasket/seals?
say goodbye to your crankshaft bearings... that motor needs to be rebuilt... ill give it 3 thousand more miles before it ***** itself.
sorry i just get so excited... as soon as your oil light turns on you should of turned the light off, that happened to me once in my 84 rex, and i blew a headgasket, scarred a sleeve, fucked up a piston... killed the mains... poor car...
and i had a friend have this happen to his si out of nowhere, and his was fully maint'ed...
just becuase the dipstick is dry doesnt mean the engine is dry of oil... you should add in a quart and then check it.. then use halfs or so until it reads normal.
your comp numbers are fine
Oops I forgot to mention that 2 quarts brought me back up to full. So I went through two quarts in about 6 months... still doesn't sound right at all. I put probally about 5-6k on the car since the last oil change.
