bleeding the clutch???
after i have the hose attached to the bleeder screw and the end of the hose submerged in the brake fluid, am i supposed to loosen the bleeder screw before i press the clutch down??
Yes you have to loosen the screw before pressing the clutch. Make sure the clutch reservoir doesn't go empty or you will get air in your line. It's a 2 person job if you ask me....one person pours brake fluid to ensure it doesn't empty and another pumps clutch and tighten/loosen bleed screw.
If you can't find a friend to help, you can place your bleeder bag on the ground you don't need a friend to work the clutch. Gravity bleeds the clutch just fine, and you can focus your attention on the cmc to make sure it doesn't drain all the way.
I have them press the clutch first then I release the screw for a second, then I retighten it and after that I tell them to release the clutch. Anything wrong with this method?
Jdmkolb89
Honda Civic (2001 - 2005)
Aug 3, 2012 10:10 PM
Sinner
Apr 27, 2006 10:44 AM
93SiHB
Oct 2, 2005 10:00 AM
