biggest difference between CTR and ITR engines
Subscribe
Apr 19, 2003 | 06:07 PM
other than the fact that a ITR has 1.8L and the CTR is a 1.6L block, the ctr is only about 10-15hp behind the ITR...what really makes the 1.6 CTR motor put out so much power...would a ctr bored out to 84mm be a better overall block than an ITR?
Reply 0
Apr 19, 2003 | 06:17 PM
Re: biggest difference between CTR and ITR engines (JeremyL)
the ctr and the itr basically have the same block. The Ctr is like a destroked itr block. The b16b also has higher compression.
Reply 0
Apr 19, 2003 | 06:21 PM
Re: biggest difference between CTR and ITR engines (VTHokie)
so it basically has a shorter stroke allowing it to rev higher and easier correct? but a shorter stroke adversly affect torque right?
Reply 0
Apr 19, 2003 | 06:57 PM
displacement impacts torque.
Reply 0
Apr 19, 2003 | 10:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> CTR motor put out so much power...would a ctr bored out to 84mm be a better overall block than an ITR?</TD></TR></TABLE>
if you bored a stock ctr block out to 84mm you'd be having some serious issues
Reply 0
Apr 20, 2003 | 12:01 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTHokie &raquo;</TD></TR><TR><TD CLASS="quote">The b16b also has higher compression.</TD></TR></TABLE>
Yes and No:
USDM ITR 10.6:1
JDM CTR 10.8:1
JDM/UK/Euro ITR 11.1:1
Reply 0
Apr 20, 2003 | 12:46 AM
The B16B makes more revs.....
Reply 0
Apr 20, 2003 | 06:15 AM
Re: biggest difference between CTR and ITR engines (BustaNutt-616)
obviously it would be sleeved first but a SLEEVED and bored to 84mm b16b block would seem like the best overall trade off for god torque and high revving
Reply 0
Apr 20, 2003 | 07:57 AM
Re: biggest difference between CTR and ITR engines (DutchITR1689)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">The B16B makes more revs.....</TD></TR></TABLE>
Redlines for the ITR and CTR are both 8400 RPM.
Reply 0
Apr 20, 2003 | 08:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">obviously it would be sleeved first but a SLEEVED and bored to 84mm b16b block would seem like the best overall trade off for god torque and high revving</TD></TR></TABLE> why do you say that? the block itself is identical to any other b18c engine once disassembled. the difference is in the crank.
Reply 0
Apr 20, 2003 | 11:57 AM
Pistons and about .2 of displacement.
Reply 0
Apr 20, 2003 | 12:30 PM
Re: biggest difference between CTR and ITR engines (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
Redlines for the ITR and CTR are both 8400 RPM. </TD></TR></TABLE>I mean where max power is developed.
BTW. the B18C6 rev limiter is at 8600 rpm
Reply 0
Apr 20, 2003 | 04:50 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BustaNutt-616 &raquo;</TD></TR><TR><TD CLASS="quote"> why do you say that? the block itself is identical to any other b18c engine once disassembled. the difference is in the crank.</TD></TR></TABLE>
b16 has a shorter deck, so its not identical.
Reply 0
Apr 20, 2003 | 05:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">BTW. the B18C6 rev limiter is at 8600 rpm</TD></TR></TABLE>
The redline and the rev limiter aren't the same thing.
Reply 0
Apr 20, 2003 | 05:32 PM
Re: biggest difference between CTR and ITR engines (Targa250R)
what about the tranny's?
Reply 0
Apr 20, 2003 | 06:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">what about the tranny's?</TD></TR></TABLE>
The CTR has the same ratios as the USDM ITR and the '96-97 JDM ITR. The '98+ JDM ITR has a longer 4th and 5th, but a shorter final drive (4.785:1 vs 4.400:1).
Reply 0
Apr 20, 2003 | 06:49 PM
Re: biggest difference between CTR and ITR engines (00 FBP ItR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00 FBP ItR &raquo;</TD></TR><TR><TD CLASS="quote">
b16 has a shorter deck, so its not identical.</TD></TR></TABLE>
Not the CTR.
Reply 0
Apr 20, 2003 | 06:57 PM
Re: biggest difference between CTR and ITR engines (Nameless EJ6)
thats right, i forgot that we were talking about the b16b.. i was thinking b16a's...
Reply 0
Subscribe
