Best Method to Remove Alternator Pulley
Old Oct 12, 2001 | 09:15 PM
Tommy_Gunns's Avatar
Default Best Method to Remove Alternator Pulley
I'm gonna put my stock pulley back on to replace the AEM underdrive pulley that I have on at the moment.
What the easiest way to remove the alternator pulley? I know I will need to remove the power steering and air conditioning belts in order to replace the alternator belt.
Would removing the driver side wheel help? Is there a way I can change pulleys without removing the alternator altogether?
Thanks.
Old Oct 13, 2001 | 03:04 AM
RagingAngel's Avatar
Default Re: Best Method to Remove Alternator Pulley (Tommy_Gunns)
well I remember the ghetto concept way we did it before..
undid all attaching belts...unbolted the alternator....and then faced the pulley towards the ground....
put on some thick gloves (to hold the pulley and keep it from spinning)... and used an impact gun and ripped that sucka off.....
threw the old/new one on held onto the pulley again with gloved hand..and gunned it back on.
No problems so far....juss get it on tight!!
Old Oct 13, 2001 | 09:15 AM
jimbob's Avatar
New User
Just be careful not to bend the pulley when taking it off. It can be pretty tough to take off sometimes. Aluminium can seize and can make taking off pretty difficult.
Old Oct 13, 2001 | 11:50 AM
yakkosmurf's Avatar
Default Re: Best Method to Remove Alternator Pulley (RagingAngel)
This is what I did with very good results. Didn't take very long either.
Old Oct 14, 2001 | 11:50 AM
Ok...I will try this, as this time I have access to an impact gun.
After closer inspection, I will need a new belt for the alternator. Stupid me forgot to tag the stock belts...what is the belt size (part number) for the stock alternator pulley.
Thanks.
Old Oct 15, 2001 | 07:11 AM
XR4racer's Avatar
Unbolt the fuel Rail and then the alternator comes right out the top of the engine bay.. took it to a tire place and had them use an air wrench to break it loose.
Old Oct 15, 2001 | 07:25 AM
eternal21's Avatar
Default We used a 32" Chromoly breaker bar...
...and that b*tch came off like it was greased
Yes, removing the driver's side wheel is the easier way to get access to it.
Old Oct 15, 2001 | 07:49 AM
Dropspeed's Avatar
Default Re: We used a 32" Chromoly breaker bar... (eternal21)
I'll ad one thing instead of holding it with a gloved hand, used the belt and pull it tight around the pulley. That holds it tight.
Mattj
Old May 8, 2013 | 10:18 AM
SiGuy's Avatar
Thought I'd throw this on here cause I prefer hand tools for assembly and I am not able to use an impact at the junk yard. The shaft itself ends in either a 10 mm or 12mm so you can use a deepwell socket on it or a socket with an extension. The nut on the alternator is the same size as the O2 sensor so you can use an O2 sensor crowsfoot on that and voila! Didn't know this method before I pick this alt up from the junkyard, looks like someone already used an impact on it by the rounded corners on the nut.
Ritchie
May 17, 2007 11:10 AM
TrueZen
May 2, 2005 03:20 PM
CKim
Mar 4, 2002 07:03 PM
CKim
Mar 4, 2002 12:43 PM
PatrickGSR94
Jan 13, 2002 10:27 AM
