best coilover?
Old Dec 25, 2008 | 02:08 PM
Ej12o3's Avatar
Default best coilover?
hey im thinking about updating my suspension just seeing what full coilover or spring strut combo you guys have had good luck and would suggest? thanks in advance
Old Dec 25, 2008 | 02:18 PM
MSchu's Avatar
My Name is Nobody
Default Re: best coilover?
Moton
Old Dec 25, 2008 | 02:25 PM
mojo_jojo77777's Avatar
Im happy with my Zeal's
Old Dec 25, 2008 | 02:28 PM
SlammedDC2teg's Avatar
There is ho best coilover. It all depends what you want to do with it.
Old Dec 26, 2008 | 02:29 AM
rhd94teg's Avatar
moton's would be great but they cost alot, im happy with my zeal and tein setups
Old Dec 26, 2008 | 02:33 AM
chargeR's Avatar
I have been happy with my Mugen N1 with swift springs setup. I wouldn't recommend them for street though.
Old Dec 26, 2008 | 05:09 AM
George Knighton's Avatar
H-T Order of Merit
You should tell people more about what you are doing with the car.
The response you got that said "Moton" is indicative of the great range of capabilities and expense involved.
Tell us what you're doing, and what your budget is.
I have Showa-made N1 on my track car. They would work well on the street with suitable spring rates and ride height, and they're so well engineered and built that they would last forever on the street, but they are probably more expensive than what the typical newbie ITR owner is going to want to spend.
Old Dec 26, 2008 | 07:40 AM
kulo's Avatar
depends what do gunna do with the car
dd
track
auto x
Old Dec 26, 2008 | 01:32 PM
itr1244's Avatar
how much are we talking here?
Old Dec 26, 2008 | 01:41 PM
Quickridez_3's Avatar
x2 i have them on my r and i cant complain.
Old Dec 26, 2008 | 01:47 PM
H-T Order of Merit
$3300 - $3500 w/custom spring rates.
Old Dec 26, 2008 | 01:51 PM
99SlammedCivic's Avatar
Snipper Snapper
I have Tein flex and love them....
Old Dec 26, 2008 | 02:18 PM
GO-FIGHT-KILL's Avatar
As far as the "Best" coilover setup... I'd recommend the Moton 4-way adjustable system. The set is around $10,000 or so if I recall correctly, but it's the best hands down. If you're looking for a BIT cheaper, I'd recommend KW Varient 3s. External resevoir, stainless steel and aluminum construction, twin coil spring per shock. The ONLY thing that kills me about KW (And is the reason I do not have a set), is that they will not disclose their spring rates. What the hell? I'm spending $3,000+ on a set of coilovers, and you refuse to tell me what I'm getting?
Anyway, you could order the set without springs, and get Eibach to custom make a rate for you. All they need is length, OD, and the rate you want. Myself however, I refuse to go through the hastle for a difference I probably wouldn't appreciate for the cost gap between what I have now.
The route I took:
D2 base coilovers with custom spring rates. Tough to beat for the price, and since I'm still generally new to tracking, I see no point in spending the better part of a quartly pay on my coilovers. Under $900 for a set of custom spring rate coilovers is tough to beat, bang-for-the-buck wise.
(And no, the shocks do not leak. That was the old style D2s that had shock issues, the new style does not. I've had them for almost a year, tracked them a few times, and they're still fine. Not to mention, D2 has an awesome warranty program... I've ONE shock come back leaking, D2 replaced it for free, and I didn't even sell the coilovers to the customer.)
Old Dec 26, 2008 | 05:40 PM
krucial7integra's Avatar
if you're not going to get a full coilover setup, then koni yellows/ground control combo is good for street setup. I had this setup a while back, then tried the tein ss, and now I'm trying out k-sport. So far, the koni's were the best setup for street.
Old Dec 26, 2008 | 05:42 PM
thabao's Avatar
buddy club coilovers for those of us on a budget!
Old Dec 26, 2008 | 05:58 PM
How did you like your K-Sports? The only thing I don't like about them, is the "stock" spring rate on the Integra/Integra Type-R/Civic kit is 9.8kg/mm front - 6.2kg/mm rear. Get some 12.1kg/mm in the rear (I typically sell them for $45 shipped for the rear set), and they're great for the money. Almost twice as stiff in the FRONT is ridiculous, I had no clue why they'd do that.
Old Dec 27, 2008 | 04:08 PM
I'm currently on the k-sports right now, they ride good until you hit a bump, feels too stiff in my opinion and they're only half way down, still got a long way to go.
Old Dec 27, 2008 | 04:51 PM
redDAinteg's Avatar
koni/gc
Old Dec 27, 2008 | 05:28 PM
trungie's Avatar
Im on H&R road race coilovers and they are pretty awesome. Good for track, but better for street.
Old Dec 27, 2008 | 06:00 PM
Really? They feel too stiff? It's typically the exact opposite complaint. Bottom out shock complaints is common, due to K-Sports weird 'stock' spring rates.
Old Dec 27, 2008 | 08:24 PM
97 TYPE-R 312's Avatar
I have PIC. I'm very happy with them. You can also rely on them for awesome customer support. These are rebuildable as well.
-Victor
Old Dec 27, 2008 | 09:21 PM
integraty95's Avatar
yeah i have the K-Sports as well they're deffinately stiff as hell. but i like them alot even for having them on a daily. not that bad in price either.
Old Dec 28, 2008 | 10:43 AM
God, if you think 'stock' K-Sports are stiff, I'd hate for you to ride around on 12kg/mm-14kg/mm rates on an Integra...
Old Dec 30, 2008 | 01:20 PM
mugenracer's Avatar
I have HKS Hypermax II's (9kg front 7kg rear springs) My car will unlikely ever see the track and so i find them perfect for street use, however i think they'd be too soft for any sort of serious track use. I had Spoon N1's on my last ITR with 14kg front and 12kg rear springs and they were fantastic, very street friendly when the damping was softened and when it was stiffened up the handling was close to perfect IMO, so if you can find a set or your budget allows, i'd recommend Spoon N1's.
Old Dec 30, 2008 | 02:17 PM
Mashimaro's Avatar
Mugenracer - did you run dustboots on these at all? are there dust boots out there that would fit over the shock body? thanks!
