backfire?
Old Dec 16, 2003 | 07:22 PM
voltageGSR's Avatar
Default backfire?
hey guys
have a JDM ITR swap done; with 2.5'' custom dual exhaust; high flow catco cat; jdm dc sports 4-1 header, aem cai, ngk wires and sparks
exhaust just installed; custom stainless with mangaflow mufflers.
getting slight backfire when i lift my foot off accelerator..
wondering if its the exhaust setup..or...?
how to most efficiently figure this out?
anyone in Cleveland, OH that could help..?
Peace
Old Dec 16, 2003 | 07:31 PM
nightrider's Avatar
Default Re: backfire? (voltageGSR)
it's because you're running rich, which is understandable. tuning will get you the right fuel mixture.
Old Dec 16, 2003 | 07:43 PM
BassBoy19's Avatar
surprising you're getting backfires with a cat even if the cat is an hi flow one.. It should block the fire...my friend are able to get a 1 foot long backfire with and old jetta 1988 only by installing a test pipe....
Old Dec 16, 2003 | 07:51 PM
JjuuN R's Avatar
dual exhaust ???
Old Dec 16, 2003 | 08:29 PM
voltageGSR's Avatar
Default Re: ([JUN]+R...)
yep dual exhaust..
seemed like a good idea at the time..
i'm hoping I can fix this problem..
i'll post a pic when i figure out how
Old Dec 16, 2003 | 08:47 PM
sjracer's Avatar
Default Re: (voltageGSR)
Are you sure it's an actual backfire or is it just a gurgling sound? The gurgling sound is common with any type of higher flowing then stock cat back exhaust.
Old Dec 16, 2003 | 09:09 PM
BassBoy19's Avatar
you can make pak! pak! pak !sounds without making flames out of your exhaust
Old Dec 16, 2003 | 09:35 PM
lustedp's Avatar
Default Re: (BassBoy19)
If it makes the "pak pak" sound but only one "pak" is that still considered backfire and running rich? My car made that noise when it was stock with only a catback exhaust....
Old Dec 17, 2003 | 05:56 AM
voltageGSR's Avatar
Default Re: (lustedp)
yea..only one 'pak' sound; no flames coming out or anything;
just the 'pak' sound when i lift my foot off the accelerator..
it is a custom built exhaust; could it be that its to much backpressure;
and bottle necking somewhere?
solutions? how to tune?
Thanks!
Old Dec 17, 2003 | 06:10 AM
len's Avatar
len
Check your TPS Voltage. I had a similar problem with my old Hondata Setup. Turns out the TPS Voltage was incorrect and everytime I let off the throttle, I got a put, put, put sound.
Now if I shift at redline, I get a huge fireball no matter what. Kinda cool, but I don't even get to see it, so what does it matter? LoL
Old Dec 17, 2003 | 11:13 AM
lustedp's Avatar
Default Re: backfire? (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
Now if I shift at redline, I get a huge fireball no matter what. Kinda cool, but I don't even get to see it, so what does it matter? LoL</TD></TR></TABLE>
you stunna
Old Dec 17, 2003 | 11:19 AM
ZygSpeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by voltageGSR &raquo;</TD></TR><TR><TD CLASS="quote">... could it be that its to much backpressure; ...</TD></TR></TABLE>
Sounds similar to when I was running a 2 1/2" exhaust on my ITR, and it's most likely due to low backpressure.
All in all, not really much to worry about in my humble opinion.
Old Dec 17, 2003 | 09:07 PM
Nuts's Avatar
Default Re: (zygspeed)
still remember seeing a clip of a Teg backfired (literally) under a bridge (in motion), sounded awesome! (for sure nothing like plah plah plah sounded...) Anyone still have that clip?
Old Dec 17, 2003 | 10:28 PM
BassBoy19's Avatar
but if you are doing like 1000 pak pak pak when releasing trottle check out your spark plugs, your probably need to change them soon... changed them on my R and the pak pak pak stopped...
Old Dec 17, 2003 | 10:51 PM
ndtITR's Avatar
Default Re: (01-1194)
backfires are awesome....when it is not your car...
Old Dec 17, 2003 | 10:58 PM
lustedp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BassBoy19 &raquo;</TD></TR><TR><TD CLASS="quote">but if you are doing like 1000 pak pak pak when releasing trottle check out your spark plugs, your probably need to change them soon... changed them on my R and the pak pak pak stopped...</TD></TR></TABLE>
changed them few days ago, "pak pak" is gone.
Old Dec 18, 2003 | 09:14 AM
voltageGSR's Avatar
must try that..change sparks and wires for that matter...maybe that will fix the problem..
what sparks u guys recommend; denso irridium?
magnacor wires?
resonable priced place to buy both?
this forum is awesome..wish i found it before my swap!
Old Dec 18, 2003 | 12:28 PM
BassBoy19's Avatar
usethe NGK oem replacement its alot less expensive than the stock denso's... and when your spark plugs needed to be changed sometimes it comes with a misfire check engine light like it is on my R right now...
Old Dec 18, 2003 | 09:09 PM
OnePointFive's Avatar
overrated.
my hatch backfires, and even shoots flames when i get on it. Running rich with no cat sucks
totsie7944
Aug 27, 2006 04:44 PM
fkneh
Jan 13, 2006 02:23 AM
touge_dorifuto
Jul 24, 2005 08:06 PM
93_teg_CT
Jun 20, 2005 07:58 PM
danny98r
Jul 21, 2004 06:09 PM
