antenna problem
Old Nov 7, 2002 | 12:37 AM
ILLTEGRA
Guest
Posts: n/a
Default antenna problem
when i shut off my car somtimes the antenna goes down like its suppose to, and half of the time the antenna stays up.
any of u guys know how to fix this?
Old Nov 7, 2002 | 12:43 AM
benmasters's Avatar
Default Re: antenna problem (ILLTEGRA)
Your aerial is probably slightly bent and also dry.
Clean with a rag and lots of wd40 and when the aerial is fully extended gently pull the top of the aerial in the opposite direction its bent in to straighten it a little.
Mine is like it, I have to clean and lubricate it every 3 weeks. Loads of us have this problem in the UK.
Old Nov 7, 2002 | 01:05 AM
skafia's Avatar
25 Year Member
Default Re: antenna problem (benmasters)
Convert it to the S2K antenna
Old Nov 7, 2002 | 01:07 AM
Bloodwynch's Avatar
Default Re: antenna problem (skafia)
I predicted someone would say that
Old Nov 7, 2002 | 01:19 AM
EddieHatchBlack's Avatar
Default Re: antenna problem (Bloodwynch)
same, but i wonder how it would look on a yellow R? i've only seen it on a black one and it looked goood.
Old Nov 7, 2002 | 03:22 AM
RStoR's Avatar
Default Re: antenna problem (Eddie HatchBlack)
Ask and you shall receive!
Old Nov 7, 2002 | 03:56 AM
ITR764's Avatar
Default Re: antenna problem (RStoR)
chris is such a show b0y!!!
Old Nov 7, 2002 | 07:32 AM
Ferrell's Avatar
hey, its my car...... minus the te37's
BTW, thanks for the kit Chris, works great.
Old Nov 7, 2002 | 08:29 AM
ITR#00-1077's Avatar
lube it up... and if not that... something might be wrong with your antenna mast.... or do what the others have done... S2K antenna....
Old Nov 7, 2002 | 09:37 AM
skafia's Avatar
25 Year Member
Default Re: antenna problem (Thai_R 1077)
You can sell the stock antenna + mast for ~45 or so and save a few lbs from the ***!
teggsr925
Feb 21, 2006 12:58 AM
fergs96integra
Jan 11, 2006 03:06 PM
R81_DC2
May 4, 2005 11:31 AM
Odessa
Audio / Security / Video
Dec 25, 2004 10:17 AM
CrazyModGSR
Jan 13, 2004 12:36 PM
