another coilover question....(teins)
Old Nov 8, 2002 | 05:37 PM
irunfromcops's Avatar
Default another coilover question....(teins)
yea i searched and couldn't get a solid answer. does anyone know how the ride height is adjusted on the tein flex dampers? do you have to change the preload to change the ride height or is the base threaded? i drive the car every day so the edfc would be a very nice thing to have but i do want the ride height and preload to be separate. i know it's not for an r but the only answer i'll get in the civic forum is to buy apc coilovers and not to waste my money on teins thanks in advance guys.
-Sean
Old Nov 9, 2002 | 11:00 AM
Default Re: another coilover question....(teins) (irunfromcops)
nobody has flex dampers?
Old Nov 10, 2002 | 08:56 AM
one last time
Old Nov 10, 2002 | 09:53 AM
4-1-1's Avatar
My car is like CSI, slow.
LOLz
Old Nov 10, 2002 | 10:06 AM
Ferrell's Avatar
Default Re: another coilover question....(teins) (4-1-1)
[I]My car is like CSI, slow.
haha
Old Nov 10, 2002 | 10:32 AM
Default Re: another coilover question....(teins) (Ferrell)
i have the greatest title evar!!
Old Nov 10, 2002 | 02:35 PM
spoon_ek9's Avatar
yea, u adjust the height with the base thread only.
Old Nov 11, 2002 | 08:49 AM
Default Re: another coilover question....(teins) (spoon_ek9)
are you positive, when i searched i saw people saying that and the opposite!! does anyone have flex dampers that can give a solid answer to this?
Old Nov 11, 2002 | 09:12 AM
Asahi's Avatar
http://www.tein.com/ti/inst/6h48u.pdf
page 5.
Read for yourself. Came straight from TEIN.com
Old Nov 11, 2002 | 11:34 AM
Default Re: another coilover question....(teins) (Asahi)
thanks alot man i didn't think to check the installation instructions they had on their site.
Old Nov 11, 2002 | 06:07 PM
JDMITR222's Avatar
They're base threaded just in case you haven't found out yet.
Old Nov 11, 2002 | 06:09 PM
B2FiNiTY's Avatar
Default Re: another coilover question....(teins) (JDMITR222)
What does that mean?
Old Nov 11, 2002 | 06:16 PM
yellow blur's Avatar
Default Re: another coilover question....(teins) (B2FiNiTY)
It means you don't have to adjust the spring height, aka preload. You can leave the coilover to have full stroke, and just adjust the height of the car by the bottom thread. It moves the shock BODY insted of making the stroke shorter.
the pdf file from tein says the spring preload and ride height adjust with the same perch....
Old Nov 11, 2002 | 06:23 PM
spoon_ek9's Avatar
that is for HA only...............
for flex, u can shorten the overall lenght(to low down the car) by using the base. the whole point of the new type flex is to able to low down the car WITHOUT affecting the stroke/proload of the shock.
sometime, the manual from tein is confusing, i got a friend who got a RE and he installed that according to the manual. at the end, we found out there is 10mm preload has been put on the spring.(14kg/mm spring, which is around 700lbs, and there is 140kg/mm preload )
Old Nov 11, 2002 | 06:31 PM
can anyone that has flew dampers confirm this? i'm going to call them tomorrow if i remember to and try and get an answer i'll post what they say if no one has confirmed it by then...thanks for your input guys
-Sean
Old Nov 11, 2002 | 08:50 PM
JDMITR222's Avatar
I have them,they're base threaded.
blindguy
18
Aug 25, 2008 01:34 PM
inj3ntek
Dec 7, 2007 09:03 AM
cornholioEK
12
Dec 25, 2003 05:21 PM
JoeyBallzSI
Oct 9, 2003 05:55 PM
beretta627
Sep 12, 2001 11:55 AM
