advice
Old Aug 25, 2002 | 11:32 PM
type_racing's Avatar
Default advice
Is it worth it to get an Apexi afc fuel control... should i not screw around with v-tec engagement and fuel cut-off??
Old Aug 25, 2002 | 11:34 PM
B2FiNiTY's Avatar
Default Re: advice (type_racing)
worth it. Don't mess with it until you get to the dyno.
Old Aug 25, 2002 | 11:35 PM
Default Re: advice (B2FiNiTY)
Why... can you expand please... thanx
Old Aug 25, 2002 | 11:39 PM
B2FiNiTY's Avatar
You won't be able to get the best results from driving it and playing around. With a dyno and wideband 02 sensor, you can see your whole powerpband along with your a/f ratio.
Old Aug 25, 2002 | 11:41 PM
ohhhh... ok i get it!! Would it make a big difference.. would i notice it?? would you get one if you have the money??
Old Aug 25, 2002 | 11:45 PM
B2FiNiTY's Avatar
I would get one once I get I/H/E at earliest. Best if you get cams and cam gears. Basically I would tune it all at once to save money.
Old Aug 25, 2002 | 11:46 PM
Default Re: advice ([B2]FiNiTY)
Whats a I/H/E??
Old Aug 25, 2002 | 11:49 PM
B2FiNiTY's Avatar
I believe you have used up all your posts. I will just spit out some info. If you want to ask more questions, you can edit your posts.
I = Intake
H = Header
E = Exhaust
C = Either Cat or Cams
Dyno - lots of different kinds. Mustang, Clayton, and Dynojet.
Old Aug 26, 2002 | 02:54 AM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
check this:
http://www.guaranteedphresh.com/~dlo/modguide
josephcmiller2
Engine Management and Tuning
14
Oct 7, 2011 01:05 PM
Teamdiesel
32
Dec 23, 2009 05:36 AM
Tbone
36
Nov 9, 2005 08:09 PM
B18C2_sedan
Sep 11, 2003 03:22 PM
2fcknfst
Aug 7, 2001 08:09 AM
