Adjustable Campulleys
Old Oct 21, 2003 | 03:04 PM
shiloh's Avatar
Default Adjustable Campulleys
Does anyone know how they are adjusted?
I´m just bought TODA Racing Forged Pistons, Lightweight Flywheel and Stage B Cams. and before I install this **** I need to know how I get the best performance out of the cams?
Old Oct 21, 2003 | 03:19 PM
ZygSpeed's Avatar
Default Re: Adjustable Campulleys (shiloh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shiloh &raquo;</TD></TR><TR><TD CLASS="quote">Adjustable Campulleys
Does anyone know how they are adjusted?</TD></TR></TABLE>
I do believe you loosen the bolts on the adjustable cams, move the outer gear portion the desired amount, and then re-tighten to spec.
If you're asking what are the appropriate/best settings, ... well, that's a different story and differs from motor to motor ...
Old Oct 21, 2003 | 03:21 PM
shiloh's Avatar
Default Re: Adjustable Campulleys (zygspeed)
I kinda hoping for someone telling whats the best setting...but hey can´t have it all can we? Thanx anyways
Old Oct 21, 2003 | 03:28 PM
ZygSpeed's Avatar
Check the area for a tuner/shop with access to a dyno.
They'll do several runs and make adjustments according to the dyno results in an iterative manner.
Old Oct 21, 2003 | 04:01 PM
RTW DC2R's Avatar
as stated, there are no standard correct cam gear settings that work best. It all depends on your set up and the only way to tune it is on the dyno.
Old Oct 21, 2003 | 09:00 PM
t's Avatar
t
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">
I think you meant move the inner gear portion; as the outer gear portion is held in place by the timing belt.
i-VTEC_DOHC
Jan 16, 2008 11:16 AM
ap1-s2k
Honda S2000
14
Nov 27, 2006 11:43 AM
japmarket1
Jun 29, 2005 12:49 PM
JBBNJ609
29
Apr 29, 2005 04:20 AM
jt-sport
20
Aug 8, 2003 08:53 PM
