ABS problem
Old Jun 21, 2005 | 05:05 PM
elnene's Avatar
Default ABS problem
I searched and found nothing about fixing these problems so any help would be appreciated. I got some abs codes and i don't know how to fix them.
32 - solenoid (short to body ground/short to wire) FR-OUT
54 - fail-safe relay
I also got this CEL code
67 Catalyst low efficiency.
I hate turning my car on and seeing these
Old Jun 21, 2005 | 06:52 PM
Ill's Avatar
Ill
Default Re: ABS problem (elnene)
JDM conversion? Check the failsafe relay and primarily it's associated wiring. It's under the radiator overflow bottle, passenger side of the radiator, attached to the core support.
Disconnect the battery for 3 minutes before working on the SRS system! Follow the Helms instructions when working on the ABS. Before disconnecting the battery, amke sure you have your radio code (usually on the side of the glove box door, or do an H-T search for that).
Clear your codes first, then recheck to be sure you really have a problem.
Old Jun 22, 2005 | 08:41 AM
elnene's Avatar
Default Re: ABS problem (Ill)
How do i clear the codes?
And also what about the CEL code how do i fix that?
thanx
Old Jun 22, 2005 | 11:37 AM
Ill's Avatar
Ill
I forget where it's located. Check the FAQ at the top of the ITR board page. I think it's on c-speed's web site.
:edit: Info on finding the codes I mean.
Clearing them is easy - Pull out the radio fuse in the underhood fuse box for 30 seconds (or disconnect the battery, but the fuse is easier).
Modified by Ill at 4:31 PM 6/22/2005
Old Jun 22, 2005 | 03:19 PM
TypeR0936's Avatar
does this always happen with jdm conversions?
Old Jun 22, 2005 | 03:29 PM
Ill's Avatar
Ill
Default Re: ABS problem (TypeR0936)
I would say it's more likely with JDM. On mine, the welder cooked a wire to the failsafe relay when he welded the JDM core in. Took me a while to find it.
Reminds me, I have to go clear my codes and see if it's fixed. He might have cooked the relay too.
Elnene: Do some more searches on H-T. Code 67 is typically thrown on a car with a test pipe or other exhaust changes. The car will run fine, but it's telling you the cat is not working as well as it could (or not at all). Post more info on your setup.
Welcome to the board!
Old Jun 23, 2005 | 10:23 AM
elnene's Avatar
Right now, all I got is aem intake, jdm 4-1 headers, high flow cat, apexi n1, and a jdm front end. You said to disconnect the battery for 3 minutes before touching the srs system why?
tony7626
Feb 17, 2012 04:50 AM
Wayne_Curr
Apr 13, 2006 03:07 PM
InTeGrA B18b1
Jul 7, 2003 04:04 PM
2qwik2nv
Dec 1, 2002 01:42 PM
