ABS codes...
Old Feb 19, 2009 | 08:23 AM
01_ITR's Avatar
Default ABS codes...
my abs light is on, im throwing codes 54-1, 16-1, and 81-1. Can anyone help me? I dont feel like bringing it to acura because they will charge me $100 an hour to look at it.
Old Feb 19, 2009 | 10:26 AM
LunchboxZT's Avatar
Default Re: ABS codes...
16-1 is for a manfunction of the right rear sensor. Could be a failed sensor or a problems with the wiring or just alot of metal shavings.
54-1 is the abs fail safe relay failure. First this is check the fuse ABS B1 20A Fuse in the under hood ABS Fuse relay box. If the fuse is good check the fail safe relay. Let me know if the relay is good. If so it will have to get alot more technical
81-1 is CPU. Once you fix the other problems this should clear.
Old Feb 20, 2009 | 04:02 AM
01_ITR's Avatar
Ohh ok thanks, ill check it today.
Old Aug 3, 2015 | 03:38 AM
muzni's Avatar
Really Stuck I got this code on my Honda GP5 Yesterday.Scanned With 54-12, 61-11,83-13,81-11.Please help huh...
Advance regard
rickyh22
Jul 18, 2009 09:18 PM
Solster
Jan 28, 2009 07:42 AM
v-tec maz
Apr 5, 2006 02:13 PM
Xaositek
Apr 14, 2004 09:26 PM
ArchAngel Sabastian
Jan 20, 2003 04:49 PM
