for all you spoon lovers...does the ventuli plate really work
Old 11-26-2001, 08:39 PM
gsr98vtec's Avatar
Default for all you spoon lovers...does the ventuli plate really work
does this gasket alone really increase hp...i have never heard of anyone using it...does anyone have it or nknow anything about it for sure
Old 11-26-2001, 09:17 PM
Mike K's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (gsr98vtec)
just picked up a used one today. my friend is going to use it on his b18c5 and try it out. i'll keep you posted.
Old 11-26-2001, 09:21 PM
Founding Member
Mike M's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (Mike K)
He'll most likely see a loss in high end but a slight gain in mid and low, The plate was actually designed for the B16A
Old 11-26-2001, 09:32 PM
Amuse9's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (TypeRmsm)
Venturi plate
Old 11-26-2001, 09:33 PM
hondura's Avatar
Nope, it does not work on the ITR motor. You will lose power.
Old 11-27-2001, 03:40 AM
New User
integra2000's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (hondura)
what about a lsvtec with a b16 head?
Old 11-28-2001, 10:01 AM
gsr98vtec's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (integra2000)
thats what i am curious to see...will it work on a ls/vtec with a b16a head
Old 11-28-2001, 10:22 AM
Founding Member
Mike M's Avatar
Its nothing to do with the B16 head, Its designed for the 1.6L engine and the B16A's cams
Old 11-28-2001, 10:49 AM
MadtownSi's Avatar
I wonder how the Ventuli plate with work on a B16 with Toda spec B cams. I wonder how much topend power you will lose. 5-6hp????
Old 11-28-2001, 08:53 PM
Dee
Dee's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (MadtownSi)
I see the rubber chicken with the Spoon stamp is still amusing you guys! Those things work so well the one that Autobacs had in their showcase three years ago is still there. Please do a before and after dyno plot for us disbelievers.
Old 11-28-2001, 09:20 PM
EG8R's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (drealgsr)
HEHEHE Why am I laffin SPOON ROCKS!! Cept for maybe this product....
Old 11-28-2001, 09:24 PM
Founding Member
Mike M's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (mr. skelly)
What the hell, Later in Dec early January I'll do a test on It, Stock Civic SI I/H/E allowed No internals Base run and a run with the Ventulli Plate.
Old 11-28-2001, 09:35 PM
junglistgsr's Avatar
ventuli = "flied lice"
lol, ENGRISH rules! its supposed to be Venturi and the Japanese are good with engrish so they changed it to ventuli!
Old 11-28-2001, 09:53 PM
beeboyee's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (junglistgsr)
coo, sounds good mike
Old 11-28-2001, 10:47 PM
csufweed's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (beeboyee)
ok, yeah it is VENTURI. As for the "Venturi effect". A good example of this would be a garden hose. Without anything on the end of it, the hose flows water at a certain amount. Add a nozzle to it or a finger or two and the water comes out at a higher rate and shoots a lot farther.
This is seen in the coffee can exhausts with silencers.(i have one, so its not an attack) Without the silencer, I feel less low end, and MUCH higher top end power! With the silencer, I get more low and mid end torque. The sound also goes from deep rumble, to buzzy but very quiet... but this is getting off topic!
Anyways, i assume that the purpose of this spoon venturi plate is to give you more low to mid end torque, HOWEVER top end suffers! My exhaust is a good example of the venturi effect and a similar result is to be expected from the spoon venturi plate.
Old 11-29-2001, 10:52 PM
csufweed's Avatar
Default Re: for all you spoon lovers...does the ventuli plate really work (csufweed)
got it?
Old 11-30-2001, 12:28 AM
Tommy_Gunns's Avatar
venturi effect:
upstream of the venturi=increased pressure, decreased velocity
downstream of the venturi=decreased pressure, increased velocity
That being said, I think that little bottle neck on the outlet side of the catalytic converter is there to decrease the velocity of the gases going through the cat (for emissions)...that's my theory.
EHondaJDM
10
01-04-2011 07:52 AM
UCI_Type-R
04-30-2007 05:52 PM
EK MONEY
09-15-2005 01:19 PM
SCsol
04-17-2002 06:41 AM
Acura97GSR
07-06-2001 10:52 AM
Quick Reply: for all you spoon lovers...does the ventuli plate really work
