#01-0154 dyno plot...
Old Oct 8, 2002 | 04:19 AM
Willard's Avatar
Default #01-0154 dyno plot...
Power mods:
-AEM cold air intake
-Honda JMD header
-Carsound cat
-~18 deg. timing
-first bottle neck restriction removed from the cat back
-power steering belt removed
-VAFC (VTEC moved and high throttle adjustments have been made)
Info:
-40,500 miles
-hot morning
-fresh plugs/rotor/cap/oil
Old Oct 8, 2002 | 04:20 AM
Reid's Avatar
Global Moderator
Default Re: #01-0154 dyno plot... (Willard)
Nice.
I need to get some time on the dyno.
Old Oct 8, 2002 | 04:25 AM
B18CXr's Avatar
tuned by the drunken arsehole known as Slack
Old Oct 8, 2002 | 04:42 AM
hooptie157's Avatar
Default Re: #01-0154 dyno plot... (B18CXr)
300hp to the wheels ehhh
Old Oct 8, 2002 | 04:44 AM
Ex-ITR5874's Avatar
You can see there`s too much backpressure somewhere in the exhaust at high rpm....... Free her and watch her scream. An engine is nothing else than just a girl.
Old Oct 8, 2002 | 04:45 AM
Brian*'s Avatar
Default Re: #01-0154 dyno plot... (hooptie157)
man i hope you are joking
nice numbers willis
Brian
Old Oct 8, 2002 | 05:19 AM
MJ23FE's Avatar
Default Re: #01-0154 dyno plot... (Brian*Black99Si)
nice numbers willis
Brian
Man i hope he is joking too, it cannot be that difficult for someone to read a dynograph measurement. Try running it again with a 2.5" cat-back exhaust and see how much more power you will get out of it, than pop it back on the dynometer, get another measurement, and maybe hoptie157 will make a similiar reading of 300whp! I'm just bustin' your chops hoptie157. If it makes you feel any better about yourself, i drive a POS! BTW, Great numbers Willis!!! I hope i can make that much power when it comes time for me to be in your shoes... yeah in about another 4 months LoL!
[Modified by MJ23FE, 9:20 AM 10/8/2002]
Old Oct 8, 2002 | 05:30 AM
Reid's Avatar
Global Moderator
Default Re: #01-0154 dyno plot... (George Knighton)
Duh...why is my VTEC spike so much more radical?
Sounds like someone is in need of a V-AFC and some Yack tuning...
Old Oct 8, 2002 | 05:37 AM
Ex-ITR5874's Avatar
S M S P
[Modified by George Knighton, 9:29 AM 10/8/2002]
He he he...
Am I right ? I know I am...
Here are my first two runs with my idol-cat-back. She`s getting stronger the higher you rev and she doesn`t flat out.
AssPenny's Avatar
Default Re: #01-0154 dyno plot... (Reid)
NC heat and alttitude own you
Old Oct 8, 2002 | 06:22 AM
Ex-ITR5874's Avatar
I think it's a rule around here. If you're going to publish your results, dyno in November (60 degrees) in Springfield (sea level). LOL...
Was this in Charlotte? When was it, and what was the temperature?
Hmmm
doesn`t your dynos correct the numbers ??
And even if they don`t.... Who cares if it`s hot or high or not ?
I think the fact that you always use the same dyno at the same place at almost the same temperature is what really counts.... To see the difference between before and after...
My dyno above was made on the hottest day in summer... the fc showed a intake-air temperature of 73°C, we sweat like pigs....
As long as we`re all running on the same track and breathing the same air if we race... who cares ?
Old Oct 8, 2002 | 06:41 AM
4-1-1's Avatar
That would be a ricers dreams to gain 130whp out of bolt-ons
Nice real numbers btw
Old Oct 8, 2002 | 09:04 AM
ITR#00-1077's Avatar
Very nice plot...
Old Oct 8, 2002 | 10:44 AM
mstewar's Avatar
nice.. very close to the route i'm already headed down.. how much of a difference do you think a full 2.5" catback would make? i've been debating taking out the 1st restriction or just plunking down the money for a catback for a month or so now..
Old Oct 8, 2002 | 11:26 AM
B18CXr's Avatar
Default Re: #01-0154 dyno plot... (mstewar)
4-5ish HP
Old Oct 8, 2002 | 12:10 PM
apexii's Avatar
Very nice Will! I think i've now been convinced to pick up the 4-1/carsound combo!!!! :rockon:
someone humor me, what is the first restriction of the catback? the bend? how is it remedied?
apex- who's R put down a meazly 161 w/ aem intake and POS bypass filter(now in trash)
Old Oct 8, 2002 | 12:29 PM
B2FiNiTY's Avatar
Good stuff!
Old Oct 8, 2002 | 04:18 PM
integratom's Avatar
Default Re: #01-0154 dyno plot... (ExOdy)
Nice looking dyno but just a guess your VTEC is at 4500 or so. If you look at the graph it looks like you get a slight dip right after that which is an indication you may have it a little to low I would reccomend about 4900 or so. Believe it or not it can have an effect to the topend why I'm not sure but that seems to be true most times.
Old Oct 8, 2002 | 05:35 PM
Willard's Avatar
Default Re: #01-0154 dyno plot... (apexii)
the flange where the cat back bolts up to the cat... and about the first 2" of the cat back.
Old Oct 8, 2002 | 05:36 PM
Willard's Avatar
Default Re: #01-0154 dyno plot... (integratom)
5200
Old Oct 8, 2002 | 06:07 PM
Jawad.'s Avatar
-Honda JMD header
there is your problem
Old Oct 8, 2002 | 06:15 PM
Willard's Avatar
Default Re: #01-0154 dyno plot... (Jawad)
daymit... I was waiting for someone to notice.
Old Oct 8, 2002 | 06:21 PM
B2FiNiTY's Avatar
I just didn't want to say you got a TDM knockoff header rather than the real JDM one.
Old Oct 8, 2002 | 06:23 PM
Turtle's Avatar
Is it me...why does it seem like your VTEC is engaging around 4300-4400 RPMs? It may just be the way the graph looks, but every time my VTEC starts to engage it starts to dip (slightly) then curve up...
Old Oct 9, 2002 | 04:59 AM
B18CXr's Avatar
Default Re: #01-0154 dyno plot... (Turtle)
it's called AEM CAI
