WTF! Engine know-it-all's please Read!!!!!!!
Old Aug 18, 2005 | 10:00 PM
KP9's Avatar
KP9
Default WTF! Engine know-it-all's please Read!!!!!!!
Some how There is moisture building up in my intake......
Seems to be coming from my Positive crankcase ventilation hose.........
The hose that goes from my valve cover to my intake
It builds up and then i cant start my car sometimes.......
But when I remove my intake and open full throttle it starts.........
WTF
no cloudy oil or sign of moisture in oil what so ever.......
I am burning oil at idle due to a leaky exaust valve seal........
Please help.......
Modified by G1tegZC at 9:03 AM 8/19/2005
Old Aug 18, 2005 | 10:15 PM
eightyHD's Avatar
1. youre head gasket is probably blown, hence radiator fluid mixing with oil evaporating "somewhere"
2. you have milky oil, meaning, headgasket is blown, or head is warped
3. youre burning oil, so your oil rings are shot!
Dude.. you need a complete overhaul.
pull the motorand have it machined if the cylinder walls are scraped or have gouges in them.
If it is light, hone it out and buy new oil rings, replace all the gasket while youre at it along with water pump and timing belt
Old Aug 18, 2005 | 10:28 PM
TODA GS_R's Avatar
that hose from the valve cover to the intake is not pcv...maybe its condensation?
Old Aug 19, 2005 | 07:59 AM
KP9's Avatar
KP9
Default Re: (TODA GS_R)
Ok
I do not have cloudyness in oil what so ever..................
My oil stays clear and doesn't even get dirty fast.......( no bad rings )
I do smoke a little oil But only at reverse vacume .....Idle and Winding down....
I know I smoke due to a bad exaust valve seal........
Could Moisture from exaust gasses be slipping through the leaking exaust valve seal the rising up to the top of the Valve cover creating moisture....moisture that never really mixes with the oil...........
I doubt I have a blown headgasket....
There is no evidence of this on my plugs
and My oil is not cloudy..........
? and Ideas or first hand experiences ?
and yes............ the hose that goes from your valve cover to your intake is part of your PCV system.........
It is part of the system that eleminates negitive pressure In your engine....and cycles the air continuouslly.........
Old Aug 19, 2005 | 12:28 PM
KP9's Avatar
KP9
Default Re: (G1tegZC)
Bump
big-cat
Aug 8, 2009 05:05 AM
JDMgunmetalCRX
Jul 8, 2009 12:49 AM
bboixtc
Mar 25, 2008 04:24 PM
rossw19
Nov 11, 2007 07:51 AM
98cwitr
Apr 27, 2004 01:34 PM
