Wiring help
Old Mar 21, 2023 | 10:45 AM
Scottdaintegra!'s Avatar
Default Wiring help
91 da with stand alone obd1 harness. Harness has plugs for computer dist. Coolant temp injectors iac map tps and alternator and a few ground wires to ring terminal. This is a circle track car so has no dash or cluster. Obviously there is no speed sensor wired into the harness but there is 1 wire from computer plug that is a vss pin just has a short wire coming from it. Do i neex to worry about this if xomputer is chipped and vss is deleted
hondaB
10
May 10, 2011 11:10 AM
be18see1
Mar 20, 2011 06:01 PM
strtrcr77
Dec 5, 2009 09:45 AM
turboblack2door
Jun 8, 2008 09:24 AM
Urban Business
Apr 14, 2002 03:52 PM
