for wing less integras
Old Jun 9, 2003 | 04:37 PM
itduzntmatter00's Avatar
Default for wing less integras
i seen that some of you guys plug the wholes w. rubber black plugs....do you happend to know the part number from honda? or a place that sells it? i also need a larger one also cuz my car had a wing w/ led....so its 5 small wholes and 1 big one please help a brotha out thanks
Old Jun 9, 2003 | 05:30 PM
KingJeff's Avatar
Default Re: for wing less integras (itduzntmatter00)
check the search.
Old Jun 9, 2003 | 06:57 PM
CNSK's Avatar
Default Re: for wing less integras (Jeff K.)
ask "patrick94gsr"
Old Jun 9, 2003 | 07:09 PM
jonoknut's Avatar
Default Re: for wing less integras (DrMartin)
home depot is your friend
Old Jun 9, 2003 | 07:17 PM
metal-x's Avatar
Default Re: for wing less integras (jonoknut)
buy an RS no need for pluggin holes lol
Old Jun 9, 2003 | 07:23 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Plastic (nylon) hole plugs from Lowe's (Home Depot does NOT stock them):
(3) 3/8" plugs and (1) 5/16" plug for the bolt holes
(1) 1/2" plug for the wing guide pin hole
(1) 7/8" plug for the wire harness hole
Old Jun 9, 2003 | 07:38 PM
JLange's Avatar
Default Re: for wing less integras (PatrickGSR94)
welded the holes shut and sprayed black primer over it
Old Jun 9, 2003 | 08:01 PM
Frito1's Avatar
Default Re: for wing less integras (jtintegra)
Patrick is right, you will not find them at home depot. I got mine at lowes and I used a elevator bolt witha washer and nut. Works great!!
Old Jun 9, 2003 | 08:02 PM
thanks pat
Old Jun 9, 2003 | 08:29 PM
Community Builder
Default Re: for wing less integras (Frito1)
an elevator what?
<--- no nuts, bolts, or washers here
Old Jun 9, 2003 | 08:35 PM
tilt's Avatar
What section are those plugs at Lowe's? I looked for over an hour and couldnt find them.
Old Jun 9, 2003 | 08:41 PM
tegasaurus's Avatar
Default Re: for wing less integras (tilt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tilt &raquo;</TD></TR><TR><TD CLASS="quote">What section are those plugs at Lowe's? I looked for over an hour and couldnt find them. </TD></TR></TABLE>
ask an employee
Old Jun 9, 2003 | 08:45 PM
Trac226's Avatar
Default Re: for wing less integras (tegasaurus)
I found the nylon plugs at Home Depot. They were in the screws and fastener sections, stored in the drawers. But, I recently switched over to 3M Plastic tape and it looks much cleaner.
Old Jun 9, 2003 | 08:56 PM
tilt's Avatar
I did, wasnt much help .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegasaurus &raquo;</TD></TR><TR><TD CLASS="quote">
ask an employee </TD></TR></TABLE>
Old Jun 9, 2003 | 09:30 PM
TerribleOne's Avatar
I bought the plugs from honda, so over priced like 11 bucks for 4 little gommits, just find a solution somewhere else, and the big one is easy to plug, make it custom everyone has a different way
Old Jun 9, 2003 | 09:51 PM
Community Builder
Look in the specialty fastener drawers, it's in the "Hard to Find Parts" section I think.
I've never been to a HD that even carries any kind of nylon hole plug.
Old Jun 9, 2003 | 11:16 PM
jonoknut's Avatar
oh yea i got mine at lowes too. . my bad. . . home depot only has chrome ones. . .*shudders*
jon
Old Jun 10, 2003 | 12:26 AM
mskibbz-T's Avatar
Default Re: for wing less integras (TerribleOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TerribleOne &raquo;</TD></TR><TR><TD CLASS="quote">I bought the plugs from honda, so over priced like 11 bucks for 4 little gommits, just find a solution somewhere else, and the big one is easy to plug, make it custom everyone has a different way </TD></TR></TABLE>
Anyone have pics of the honda ones installed? I have a dark blue teg and am wondering how noticeable they will be. If only they were painted factory colors... I would nut right here and now
Old Jun 10, 2003 | 09:42 PM
do you happend to have the part number?
Old Jun 10, 2003 | 10:07 PM
yes I do.... 91601-SR3-000 they are rediculously $$$ like 2 bucks a plug and you need 4...super OEM cleaness tho
Old Jun 10, 2003 | 10:16 PM
integrasi's Avatar
just go weld that sucker up.
Old Jun 10, 2003 | 10:18 PM
lshobo's Avatar
Default Re: for wing less integras (integrasi)
electrical tape and oem touch up paint that's only if you don't care and plan on getting a paint job in the future anyway
Old Jun 10, 2003 | 10:19 PM
tilt's Avatar
Thanks, I found them, installed them, my spoiler was faded so wingless looks nice. The three 3/8" plugs were a bit too big so I got creative and forced them to fit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">Look in the specialty fastener drawers, it's in the "Hard to Find Parts" section I think.
I've never been to a HD that even carries any kind of nylon hole plug.</TD></TR></TABLE>
Old Jun 11, 2003 | 09:23 AM
Default Re: for wing less integras (lshobo)
thanks for all the help i got mines at lowes too yea the 3/8's were kinda big but i stuffed it in there..... i will also go buy the rubber ones ffrom honda also thanks guys
Old Jun 11, 2003 | 09:29 AM
J337_UNIT's Avatar
i had the holes welded and antenna and keyhole all welded shut too
Peruviann83
May 7, 2007 02:13 AM
Nameless Warrior
Mar 23, 2007 07:41 PM
alfaaay
Aug 27, 2006 07:32 AM
Kryptonite
Jan 13, 2004 09:42 PM
