windshield problem
Old May 5, 2003 | 06:54 PM
integraL's Avatar
Default windshield problem
i just got my car back from the bodyshop...and i noticed that some part of my windshield was foggy...i tried using glass cleaner...but its tough to get off...anyone else have this probleM?
Old May 5, 2003 | 07:06 PM
Al Bundy's Avatar
Default Re: windshield problem (izkevin)
What do u mean foggy? As in it fogs up? Or is it permanent?
Old May 5, 2003 | 07:07 PM
93gsrgirl's Avatar
was it clear coat over spray if you take a flat razorblade you will be able to scrape it off then use paint thinner to get the final crap. Then wash as directed on the windex bottle ( I would use black and white news paper no streaks) If not then check your heatercore
Old May 5, 2003 | 07:44 PM
integraL's Avatar
Default Re: windshield problem (93gsrgirl)
its little dust seems to be stuck on the outside of the windshield...and its kinda rough when i run my fingers over it...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93gsrgirl &raquo;</TD></TR><TR><TD CLASS="quote">was it clear coat over spray if you take a flat razorblade you will be able to scrape it off then use paint thinner to get the final crap. Then wash as directed on the windex bottle ( I would use black and white news paper no streaks) If not then check your heatercore </TD></TR></TABLE>
wont i damage the windshield?
Old May 5, 2003 | 09:04 PM
roydogg's Avatar
Just use some faom glass cleaner and a razor blade. Is the glass distorted?
Old May 5, 2003 | 09:12 PM
integraL's Avatar
Default Re: windshield problem (roydogg)
well it makes the view a little foggy/blurry...like its cloudy. how would i use a razor blade without scratching it..im afraid i might damage it permanently
Modified by izkevin at 10:32 PM 5/5/2003
Old May 5, 2003 | 10:40 PM
roydogg's Avatar
Thats why I said use foamed glass cleaner. I work for safelite autoglass and thats what we use everyday to clean the glass. If it's distorted then it could have been scratch but was buffed which cause the distortion in the glass. Or it it could be some paint,primer,clearcoat,etc... from the shop.Try it and let me know what happens.
Old May 5, 2003 | 10:50 PM
integraL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roydogg &raquo;</TD></TR><TR><TD CLASS="quote">Or it it could be some paint,primer,clearcoat,etc... from the shop.Try it and let me know what happens.</TD></TR></TABLE>
i think you're right...its gotta be primer or clearcoat, etc. and tried scratching it with my nail and a little came off. so i should use foam glass cleaner and a razor blade used in box cutters?
Old May 5, 2003 | 11:43 PM
JDC2's Avatar
damn i hate it when shops don't take the time to mask off areas.
Old May 5, 2003 | 11:50 PM
integraL's Avatar
Default Re: windshield problem (JDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDC2 &raquo;</TD></TR><TR><TD CLASS="quote">damn i hate it when shops don't take the time to mask off areas. </TD></TR></TABLE>
what exactly is masking off?
Old May 5, 2003 | 11:56 PM
Adachi's Avatar
93GSRGIRL is right.. just spray on some water (or windex), take a razorblade and scrape it off (at about a 45 degree angle). Trust me, it won't scratch your glass at all.
Old May 6, 2003 | 12:08 AM
Takumi Fujiwara's Avatar
Default Re: windshield problem (Adachi)
Why don't you just take it back to the shop?
Old May 6, 2003 | 12:14 AM
integraL's Avatar
Default Re: windshield problem (Takumi Fujiwara)
i hate that place its sooo dusty..and itd be nice to just do it in my garage
Old May 6, 2003 | 02:43 PM
JDC2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by izkevin &raquo;</TD></TR><TR><TD CLASS="quote">
what exactly is masking off?</TD></TR></TABLE>
thats when they're suppose to cover up the areas where they are not suppose to spray windows, moldings, grill, ect...
Old May 6, 2003 | 05:33 PM
93gsrgirl's Avatar
If your very careful and dowse the windshield with pait remover the take your blade and anlge it so it rests almost flat with the windshield you will be able to scrape it off thats how I.ve done it in the past workd like a charm if you get the thinner on your paint don't panic ive done that as well to remove tar just get a all purpose cleaner and remove the thinner. Window tinters use blades all the time to remove tint and if your careful and take your time you wont wreck your glass. Trust me it works Sorry for the late reply I went out last night and I just got back to the board now
user 931176363637
Paint and Body
Nov 2, 2008 01:45 PM
dohc_profile
Paint and Body
May 18, 2007 03:54 AM
FBPSidan
Feb 6, 2006 11:11 AM
Jap Ek9
Mar 27, 2004 07:59 PM
Ti3d in
Feb 16, 2004 08:12 AM
