Will this work, intake?
Old Feb 24, 2004 | 04:50 PM
speedehatch's Avatar
Default Will this work, intake?
So i know i can use an ITR ram intake on my d16y8 manifold. The reason i am doing this is b/c the piping is a bit bigger, and the way it bends it will clear where i have my alarm set in my engine bay. I cant find many ITR intakes, will an RS/LS ram intake work as well? Do they have the same bends as the ITR?
Old Feb 24, 2004 | 05:59 PM
carcala's Avatar
Default Re: Will this work, intake? (speedehatch)
im sure u can use the ls/rs intake. type r and ls/rs have pretty much the same intake. except in size where u can get a 3 in. for the type r
Old Feb 24, 2004 | 06:16 PM
Default Re: Will this work, intake? (carcala)
anyone else care to agree or disagree
Old Feb 28, 2004 | 06:47 AM
Come on i need some more advise. Are the d16y8 and b18b throttle bodys the same size? If they are it should fit right?
Old Feb 28, 2004 | 08:16 AM
shamoo's Avatar
Will you make something up for me please?
Yes. is correct. The Type R and the LS/RS/GS intakes will be the same except the ITR one will be a larger diameter.
The only ones you might have to modify to fit (or might not fit at all) will be the GSR ones. The intake manifold is different and the throttle body is physically set deeper down in the engine bay.
Old Feb 28, 2004 | 08:40 AM
Default Re: Will this work, intake? (shamoo)
Thank you very much for clearing that up for me guys. I had a feeling the only difference was the size, type r being 3 inches. thanks again.
DrewQ1
Jan 31, 2005 07:31 PM
speedehatch
Feb 24, 2004 10:54 AM
Mike95lude
Jan 10, 2004 08:05 PM
DOHc SIdE
Mar 27, 2003 04:46 PM
Weslay
Mar 5, 2002 05:39 AM
