Will this swap work??
Old Jul 17, 2011 | 05:22 PM
jorgejam2001's Avatar
Default Will this swap work??
So decided to swap a b18b1 in my 97 integra gsr until i get $$ to get another gsr engine or rebuild it.... does anyone know if itll be plug an play or do i have to make any modifications? also can i use the gsr manifold and distributor and axles and ecu from the gsr on the b18b1?
Old Jul 17, 2011 | 06:16 PM
my96GSRteg's Avatar
Default Re: Will this swap work??
im pretty sure its just the motor and ecu. and you have to use the Ls mani cause the gsr wont fit.
Old Jul 17, 2011 | 09:59 PM
mouab18c1's Avatar
You cannot use the GSR IM on the ls motor. You can however use the axles and distributor from your gsr swap. You will need an ls ecu.
Old Jul 19, 2011 | 03:40 PM
jdmrexy90's Avatar
a vtec distributor will not fit on a non-vtec head
Old Jul 19, 2011 | 04:37 PM
mouab18c1's Avatar
Are you sure? A non vtec dizzy works on a Vtec motor.
Old Jul 20, 2011 | 04:41 AM
95BG33PGSR's Avatar
it will work but you will have to swap the GSR dizzy guts into the LS dizzy body...I have the guts from an LS on my b18c and it works fine
Old Jul 20, 2011 | 10:23 AM
dc101's Avatar
put the gsr head on the ls block, you get to keep your im, your ecu ect....
Old Jul 20, 2011 | 10:39 AM
mouab18c1's Avatar
They're all the same
Old Jul 20, 2011 | 02:07 PM
dc4ok's Avatar
Different wire harness isn't it
Red-Rag-B18
Mar 5, 2010 01:24 PM
jikespingleton
Dec 2, 2006 04:18 PM
sasinorm01
Jul 15, 2004 01:54 PM
civura R
Oct 4, 2002 02:58 PM
KLN
Mar 11, 2002 09:52 PM
