WILL IT RUB
Old Nov 25, 2004 | 02:52 PM
jdmdochvtec's Avatar
Default WILL IT RUB
I have a 93 Integra. I have the Rota Slipstream 16on 205/50/16. If i put the lowest profile. Will it rub? does anyone have pics on a DA with 16s droped with low pros? because on 15's the low profiles arent as low as i want them to be. please help .. thanks ...
Old Nov 25, 2004 | 02:54 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: WILL IT RUB (jdmdochvtec)
Well, it's quite hard to tell if we don't know what type of springs/coilovers you are using.
16 inch wheels/tires (low profile or not) aren't THAT big and won't rub on most applications. It all depends on how low you are. Did they rub with the 15's? You should keep the profile in proportion with the rim size so you have the same rolling diameter.
That way you know it won't rub whether you have 15's or 17's.
Old Nov 25, 2004 | 03:59 PM
Default Re: WILL IT RUB (shamoo)
Either GROUND CONTROL coilovers or SKUNK2 coilovers with KYB's on da **** ...
Old Nov 25, 2004 | 04:00 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdochvtec &raquo;</TD></TR><TR><TD CLASS="quote">Either GROUND CONTROL coilovers or SKUNK2 coilovers with KYB's on da **** ... </TD></TR></TABLE>
Again, how would we know? It depends on how much you lower it, right? If it rubs, raise it a little. Simple.
Old Nov 25, 2004 | 04:55 PM
Elemental's Avatar
^ totally ^
My friend with a da (lowered on bomz coilovers ) is on 17's and doesnt rub.
his front is about as low as you want to go. He probably has another 1-2 finger wheel gap too.
Old Nov 25, 2004 | 06:10 PM
MR5sARECOOL's Avatar
Default Re: WILL IT RUB (Kyoushu)
offset is whats important
Old Nov 26, 2004 | 02:28 AM
Default Re: WILL IT RUB (MR5sARECOOL)
okay ... i wanna SLAM the **** ... what u mean by offset? bcoz im just gonna slam it enough so u cant put any fingers in there ... Do you think Skunk2 or Ground Controls are a good set of coils tho ? and how much should i be looking for in the price for the coils? ... (you guys are helpin me alot .. thanks )
Old Nov 26, 2004 | 05:38 AM
GG-SquadDB's Avatar
i have GCs on tokico illuminas and im not slammed on slipstream 15s and havent had a problem i wouldnt slam it though but thats just me its going to make ur ride uncofortable and eat tires real quick i paid i think around 200 for my coils and a little bit more for the struts... i wouldnt slam it on the stock shock/struts but thats just MO ... its ur ride not mine if ur gonna slam ur gonna need a camber kit
Old Nov 26, 2004 | 10:30 AM
sykotic's Avatar
Default Re: WILL IT RUB (GG-SquadDB)
hope the roads are damn nice where you live...
Old Nov 27, 2004 | 12:06 AM
okay ... one last question ...
Skunk2 or Ground Control ... pls lemme know why one is better ? thanks!
Old Nov 27, 2004 | 08:26 AM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmdochvtec &raquo;</TD></TR><TR><TD CLASS="quote">okay ... one last question ...
Skunk2 or Ground Control ... pls lemme know why one is better ? thanks! </TD></TR></TABLE>
Differences are negligible. Same as far as I'm concerned.
As with the rubbing issue. Since you are using those threaded coils, just drop it as far as you can until it rubs. Trial and error is the only thing you can do when you want to "slam" it as much as you can.
We can't tell you what will happen. We don't know how much your setup weighs. We can't say "Drop it 4 inches" because what does that mean to you? 4 inches lowering on the coil, doesn't necessarily equal a 4 inch drop. It's all trial and error with those things.
Good luck.
drkros3
Sep 28, 2006 05:30 AM
n-line4
Feb 23, 2005 10:32 PM
01nhbgsr
Dec 28, 2002 05:50 PM
bocian
Mar 13, 2002 08:27 AM
2fastcivic
20
Jan 19, 2002 10:18 AM
