Will my computer throw a code w/ no cat?
Old Apr 15, 2003 | 08:42 PM
Boosted GSR's Avatar
Default Will my computer throw a code w/ no cat?
i have a 95 gsr, obd1 and i wanted to put a straght pipe on their. would the comp. throw a check engine light?
Old Apr 15, 2003 | 08:50 PM
:jdmshmaydm:'s Avatar
Default Re: Will my computer throw a code w/ no cat? (Boosted GSR)
Nope. You're good.
Old Apr 15, 2003 | 08:51 PM
riceball777's Avatar
nope
Old Apr 15, 2003 | 08:53 PM
Default Re: Will my computer throw a code w/ no cat? (riceball777)
what do i do with that sensor then that plugs into the cat?
Old Apr 16, 2003 | 12:46 AM
If there's a sensor that plugs into the cat then you will throw a code. I understood that OBD1 cars didn't have the O2 sensor on the cat. The code thrown will be, "67 - Low Catalytic Converter Efficiency."
Old Apr 16, 2003 | 05:25 AM
Evilteg's Avatar
Default Re: Will my computer throw a code w/ no cat? (Gatecrasher19AF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gatecrasher19AF &raquo;</TD></TR><TR><TD CLASS="quote">If there's a sensor that plugs into the cat then you will throw a code. I understood that OBD1 cars didn't have the O2 sensor on the cat. The code thrown will be, "67 - Low Catalytic Converter Efficiency."</TD></TR></TABLE>
true, btw nice sig, what r u 12??
Old Apr 16, 2003 | 06:08 AM
JimBlake's Avatar
No, the '95 is OBD-1...
I've got a '95 GS-R and the single O2 sensor is in the catalytic converter, but its UPSTREAM of the catalyst core. So its just like having it in the A-pipe. You need to get a sensor fitting welded into your test pipe, basically putting the sensor where it would have been...
The OBD-II cars had the 2nd sensor in the middle or the end of the catalyst, so it could measure the exhaust after it had already passed thru most of the catalyst.
Old Apr 16, 2003 | 07:13 AM
jabroni95gsr's Avatar
Default Re: Will my computer throw a code w/ no cat? (JimBlake)
just get a cheap obx one from ebay that had the bung in it already for the o2 sensor...approx $50
Old Apr 16, 2003 | 07:23 AM
P1mpSlap's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
Well put.
When I was going to get my carsound cat put in, the guy bitched a fit b/c the car sound cat didn't have a bung for it.
SO OBD1 cars DO have 1 sesnor at the front
OBD2 GSR's have 1 senor at the front and 1 senor in the middle or in the back.
scott_turner
Apr 30, 2011 04:14 PM
nutball72
Aug 10, 2007 03:05 PM
spray_bombed
Jul 22, 2007 04:14 PM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
DelsolVtec18
Sep 6, 2001 01:11 AM
