Will this dent in the header make a performance difference?
Old Mar 9, 2002 | 04:37 PM
araknis's Avatar
New User
Default Will this dent in the header make a performance difference?
I'm thinking about buying this DC JDM header, but there is a dent in it. I'm just wondering if it will hinder performance or if it can be easily fixed.
[Modified by araknis, 1:38 AM 3/10/2002]
Old Mar 9, 2002 | 06:26 PM
csufweed's Avatar
Default Re: Will this dent in the header make a performance difference? (Teken)
the piping is actually quite thick so a dent like that wont decrease performance... only concern is if you bottom out again then the header may stretch further and eventually rip a hole in it.
Old Mar 9, 2002 | 09:15 PM
araknis's Avatar
New User
Default Re: Will this dent in the header make a performance difference? (csufweed)
I currently have eibach prokits on my car. What are the odds that I bottom out with this header on? Also, is the only other part I need a 2.5" cat? I have a 2.25 catback rsr exhaust right now and I want to bolt this guy on.
Old Mar 9, 2002 | 09:18 PM
deMad10's Avatar
Default Re: Will this dent in the header make a performance difference? (araknis)
It will only create turbulance inside the header if the dent protrudes inside the piping. It is like sticking your hand out the window at 60 mph. The wind will have to go around your hand where it would have just gone straight through before.
You shouldn't have a problem with bottoming out if you only have prokits.
[Modified by deMad10, 6:18 AM 3/10/2002]
Old Mar 9, 2002 | 10:09 PM
csufweed's Avatar
well i had the same header and the eibach pro kit... bottomed out a couple times and then it stopped cuz i had in a sense solved the clearance problems by denting the header. Air flow is still adequate and all. chances are the header won't cause you to bottom out much, and most likely it will end up like how mine did... all DC 4-1 headers are known for clearance problems, but after a few times bottoming out, it wasnt an issue anymore. Just take it easy over speed bumps and such and you'll be fine. If you need a cat, order up one... if you really could care less, cuz the exhaust is restricting flow anyways, then go to a muffler shop and pay them like $20 to make a custom flange to fit.
nObOdy65
Oct 5, 2005 10:19 AM
95lstegman
Jan 24, 2005 08:04 PM
Catera
Oct 22, 2004 07:28 PM
SpdFrk
Feb 2, 2003 07:24 PM
