When changing MTF
Old Feb 15, 2004 | 08:56 PM
5spdIntegra's Avatar
Default When changing MTF
I heard it's a good idea to change washers when you change your transmission fluid. I suck really bad at these illustrations so I need someone to help me out with the part number's for the fill and drain washers.
Old Feb 15, 2004 | 09:17 PM
inzaneN1's Avatar
From: INZANE FOR PRESIDENT 2008 .., las vegas nv, U.S.of.A
Default Re: When changing MTF (5spdIntegra)
washer #20 and #21 are most likely the ones u need to change when i changed my tranny fluid i didnt change washers
NXSpoon's Avatar
Drain bolt is #12, fill bolt is #18. I changed my fill bolt washer, but not my drain washer. Do NOT lose the drain washer, Honda rarely has these in stock.
No leaks so far, and I don't see any happening in the future, just torque it down to the correct spec.
Old Feb 15, 2004 | 09:41 PM
Default Re: When changing MTF (NXSpoon)
Thanks guys!
Old Feb 15, 2004 | 10:17 PM
lke2drvgsr's Avatar
remember to use gm synchromesh friction modified
Old Feb 15, 2004 | 10:48 PM
NXSpoon's Avatar
Default Re: When changing MTF (lke2drvgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lke2drvgsr &raquo;</TD></TR><TR><TD CLASS="quote">remember to use gm synchromesh friction modified </TD></TR></TABLE>
Hell yes !! Just put it in, good stuff. The GM dealers might not be sure what it is, I had to call 3 of them before I finally reached one that understood. It comes in the SQUARE bottle, like motor oil, NOT the ROUND bottle.
meccA's eg6
Honda S2000
20
Sep 18, 2007 06:03 PM
Kyles ej1
Sep 23, 2004 04:41 PM
Slammd Sol
Mar 28, 2004 10:21 AM
Too_Funny
Nov 8, 2002 03:34 PM
