Wheel Stud
Old Feb 14, 2014 | 07:46 PM
hondafdj444's Avatar
Default Wheel Stud
I was taking off my wheel slugs when I broke the stud itself.
I bought a new one, removed the caliper, took the brakes off, got the stud by itself but it turns out I have to take the hub off. To do that I have to remove the wheel bearing to get at the stud, to put the new one in.
My question is: Can I REPRESS the wheel bearing AFTER I have taken it out of the hub? Or do I need a new one?
Old Feb 14, 2014 | 08:24 PM
B_Swapped93's Avatar
Default Re: Wheel Stud
http://www.team-integra.net/forum/19...ud-repair.html
yes you 99% of the time will need to replace them afterwards.
Old Feb 15, 2014 | 12:49 AM
m4xwellmurd3r's Avatar
I got lucky when I replaced my studs. The hub came apart clean without messing anything up. I also found out that the ball joint seperators that utilize two arms are great for hand pressing studs in. You crank them down like youre trying to pop a ball joint. If it stops going throigh you can take a dead blow hammer to assist it. Since the ball joint separator is already putting pressure on it, the stud can get hammered in pretty easily.
I didnt have a press :/
Old Feb 15, 2014 | 05:24 PM
1998GsRIntegra's Avatar
Old Feb 15, 2014 | 06:10 PM
safedriver's Avatar
I broke a stud, last year.
I got the parts and I found a local Machine Shop, they charged me $40 to:
press out all of the studs,
press in the new studs,
press out the bearing,
press in the new (oem) bearing.
Get on your local Honda/Acura site and ask which Machine Shop to use.
Old Jun 20, 2014 | 12:27 AM
vartok's Avatar
I know this thread is a few months old... but does anyone see any issue with replacing one of the studs how Eric replaced it?
if it matters, my GSR has the 5 lug conversion.
cmfnelson
Nov 24, 2012 01:03 AM
Pompiuses
Sep 12, 2005 06:57 AM
tilt
Mar 2, 2003 06:08 PM
performula
Feb 19, 2003 03:08 PM
InfamousRS
Feb 11, 2002 09:36 PM
