Wheel stud....
Old Nov 22, 2006 | 07:27 PM
MyFirsTmk1's Avatar
Default Wheel stud....
Ok first off im sorry if im posting in the wrong spot....i have a 92 integra gs and one day i tighten the wheel bolt a lil too tight and broke the stud off....i went to a place too see how much they would charge to replace it and they said between 50-100 bucks...i sed F that.....so i was wondering if anyone here my know how to do it...if its a simple push out push new one in or hammer it in....any pictures or just anything and ill do it myself...i rather do it myself cause then that something else i know how to do for if i ever need to do it again....thanks for you help and again im sorry if i posted in the wrong section...i tried doing a search but didnt know wut specifically to put...so if there is a forum to one..please direct me to one...thanks
Old Nov 22, 2006 | 07:34 PM
Rikter's Avatar
You have posted in the right spot.
You'll need to take the wheel off and get the hub off as well. From there you should be able to press out the broken stud and in with the new stud. If you don't have a press but you can take off your hub I'd just take the hub to a shop and ask them to press out the broken one and press in the new one. That'll be much cheaper for you as a shop would charge you for all the labour to take off the hub, etc.
-Rik
Old Nov 22, 2006 | 07:46 PM
MyFirsTmk1's Avatar
Default Re: (Rikter)
ok coo awsome thanks
Old Nov 22, 2006 | 08:13 PM
JDM_DC4_Fanatic's Avatar
Default Re: Wheel stud.... (MyFirsTmk1)
you dont need a press. At work, all we do is bang the broken stud out with a hammer. To install the new stud is a bit tricky without an impact gun, but you can do it with a ratchet. You place the new stud into the hole in the hub, find some washers with a hole BIGGER then the stud itself, and put the lug nut on. As you tighten the lug nut, it will pull the stud into the hub. you NEED the washers for this, because the lug nut will bottom out against the hub before it is properly tightned, so try and find something that will space the lug from the hub.
Old Nov 22, 2006 | 08:16 PM
Sam92Teg's Avatar
I think the fronts are more difficult than the rears. On the front, the hub has to be separated, then new studs installed, but then the hub has to be pressed back together and sometimes the bearing gets trashed during this process. So some shops will advise replacing the wheel bearing while your there. On the rears, I have heard its a piece of cake, knock out, knock back in or use lug nuts to pull thru.
Old Nov 22, 2006 | 08:45 PM
aladosis's Avatar
Default Re: Wheel stud.... (JDM_EK_Fanatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_EK_Fanatic &raquo;</TD></TR><TR><TD CLASS="quote">you dont need a press. At work, all we do is bang the broken stud out with a hammer. To install the new stud is a bit tricky without an impact gun, but you can do it with a ratchet. You place the new stud into the hole in the hub, find some washers with a hole BIGGER then the stud itself, and put the lug nut on. As you tighten the lug nut, it will pull the stud into the hub. you NEED the washers for this, because the lug nut will bottom out against the hub before it is properly tightned, so try and find something that will space the lug from the hub. </TD></TR></TABLE>
instead of using washers i used my brake rotor
dc2luva
Apr 10, 2009 03:45 PM
lostda9
Aug 1, 2008 08:23 PM
dre2day
Feb 16, 2008 07:56 AM
JDMJunior
Mar 26, 2006 09:34 PM
mckenzie
Jul 13, 2002 10:34 PM
