wheel bearing
you should try the search button bcuz sombody might have gone deeper into this matter. but as far as i kno, unbolt the a arm, tie rod & lower arm from the knuckle, remove the brake caliper and that should be it. then just take it to a machine shop along with the new bearing and ask them to press the old one out & the new one pressed in. but do try the search button just to be sure, good luck to you
I just got done with replacing mine outta 93 integra. I think they are sealed bearings as mine was buy a new one from parts store .. Then just take apart whole knuckle. Its not hard at all.
