What's wrong with my alignment?
Old Jul 5, 2003 | 09:10 AM
integra15's Avatar
Default What's wrong with my alignment?
The insides of my tires are getting eaten up and I need to correct it quickly. I have recently installed a set of type R springs (about 1in drop) and kyb agx shocks on my gsr. The alignment does not feel that bad but I took a look at the tires today and they are geeting worn bad on the inside. As far as I know camber is not ajustable on integras, but I can see that the caber looks bad. So can a alignment fix this problem or do I need to buy a camber kit? Can anybody help me out here?
Old Jul 5, 2003 | 09:13 AM
Sukebei Oni's Avatar
Default Re: What's wrong with my alignment? (integra15)
well, you do need an alignment, and you are probably going to need a camber kit fix it.
Old Jul 5, 2003 | 09:16 AM
tub_sephiroth's Avatar
You probably don't need a camber kit. You just need to go get an alignment and get your toe adjusted. Toe eats more tread that camber.
Old Jul 5, 2003 | 10:18 AM
Default Re: What's wrong with my alignment? (tub_sephiroth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tub_sephiroth &raquo;</TD></TR><TR><TD CLASS="quote">You probably don't need a camber kit. You just need to go get an alignment and get your toe adjusted. Toe eats more tread that camber.</TD></TR></TABLE>
its more a combination of the two that eats the inside tread of the tire.
Old Jul 5, 2003 | 10:46 AM
justininhifi's Avatar
When you change springs you throw the toe off way more than the camber. I dont think camber eats tires that much at all if you get an alignment soon after you install springs and keep a good rotation.
BLeSR
10
Mar 17, 2010 08:32 PM
dwarrick
May 11, 2006 10:20 AM
donger
Jan 30, 2006 01:10 PM
EgRedSi
19
Dec 8, 2004 02:04 PM
JunIntegra
Apr 4, 2004 09:09 AM
