what's with the bumpy ride ???
Old Dec 8, 2003 | 12:37 AM
black sohc civic's Avatar
Default what's with the bumpy ride ???
i was entering a highway with barely any shoulder so i revved hard to merge. i dropped the clutch at around 5500rpm and shifted hard 1st to 2nd, and 2nd to 3rd. after i exited off the highway, i noticed at around 35-40mph the car was a tiny bit bumpy, as if the wheels were unbalanced. then by the end of the night, once the car was in motion, the ride was ridiculously bumpy. what the crap did i do? did i break an axle, a rotor, or what?!
Old Dec 8, 2003 | 08:14 AM
Default Re: what's with the bumpy ride ??? (black sohc civic)
help!
Old Dec 8, 2003 | 09:27 AM
SuzukaBlueAP2's Avatar
please explain what you mean by "bumpy" ? Can you feel it in the steering wheel ? you need to describe the feeling a little better...
sounds like you could've maybe just thrown a wheel weight off and now they are out of balance...i've heard of that happening before...
Old Dec 8, 2003 | 09:43 AM
SlalomHonda's Avatar
I'm only posting this because it happened to my sister yesterday and my Teg today...
She called and complained of an incredibly horrible vibration at highway speeds. I had no idea, until I got on the highway myself this morning in my Teg and had similar vibrations. I got off the next exit and cleaned out the snow in and behind my wheels, around the brakes, etc. Got back on the highway, and was smooth as silk. I've driven for 7 years in new england now, and never had that happen, but it happened to me (in NH) and my sister (in NY) within 12 hours of each other, right after a big snow storm. Noticing that you're from NJ, it's worth a shot I guess.
Old Dec 8, 2003 | 05:49 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (SlalomHonda)
nasty road vibrations usually indicate a worn inner CV joint or missing balance weight on the CV axle shaft.
Old Dec 8, 2003 | 06:54 PM
Riceburner247's Avatar
Default Re: (PatrickGSR94)
You yourself should probably jack the car up and take the tires off. Look under there for any torn boots or bent axles or anything suspicious. Get back to us.
bads2k
May 28, 2008 03:40 PM
tuckin15s_8315
Suspension & Brakes
Mar 29, 2006 08:31 AM
u2slow
Dec 28, 2005 09:09 PM
BANGBANG
Sep 26, 2004 08:46 AM
zizux
Aug 28, 2003 01:11 PM
