what are some basic mods for a new integra
Old Jul 10, 2005 | 07:15 AM
murk593's Avatar
Default what are some cheap basic mods for a new integra
I just got my integra Ls and im looking for some inexpessive and effetive ways to boost my h/p a little. does removing the air box do anything?
Modified by murk593 at 8:49 AM 7/10/2005
Modified by murk593 at 8:52 AM 7/10/2005
Old Jul 10, 2005 | 07:19 AM
0h teh sl0w k20!!'s Avatar
Default Re: what are some basic mods for a new integra (murk593)
i/h/e...
Old Jul 10, 2005 | 07:24 AM
Danziver's Avatar
cams
Old Jul 10, 2005 | 07:34 AM
murk593's Avatar
i dont understand what the first guy said but some one told me if you take out the air box and leave the filter it sounds better and you gain h/p for my ls
Old Jul 10, 2005 | 07:37 AM
weak_tec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murk593 &raquo;</TD></TR><TR><TD CLASS="quote">i dont understand what the first guy said but some one told me if you take out the air box and leave the filter it sounds better and you gain h/p for my ls</TD></TR></TABLE>
he meant intake, header, and exhaust
Old Jul 10, 2005 | 07:54 AM
Integra GSR 95's Avatar
Basic mods as someone else already said Header, Intake, Exhaust. Then you can do intake manifold if you want to take it father. Cams are not so much basic. You are talking money when you replace those. But they do give you more HHHHHHPPPPP!!!
Old Jul 10, 2005 | 08:33 AM
apok's Avatar
Default Re: (Integra GSR 95)
Throw in an LS1 if you want some torque.
Old Jul 10, 2005 | 09:11 AM
Lewie's Avatar
I'm here for the gangbang!
Nitrous.
And please stop posting any more stupid questions. Next time use the search button.
» Search Results
Your search for mods returned 59 results.
Old Jul 10, 2005 | 01:46 PM
AllMotorDan's Avatar
get an intake, header, exhaust. I'd recommend you do research (used the search button) and find whats the best parts for your car such as what header to get, what exhaust to get, what intake to get. Team-integra.net has a bunch of purchsing guides to help you with this kind of stuff...Good luck with the serach and keep us posted on the parts you choose to buy
Old Jul 10, 2005 | 03:05 PM
TEG DRIVER's Avatar
Default Re: (SpoonSirG)
what i've done to mine so far is exhaust and i got an intake in the mail and springs and then as soon as intake gets here i'll be heading to the NOPI store and get me a K&N filter. then i plan on getting a header on ebay cause i figure why spend $300.00 on a 4-2-1 header when i could get one from ebay for about 1/3 of that.
Old Jul 10, 2005 | 05:13 PM
^ if thats how you think about it then cool, i've always believed in the saying you get what you pay for though.
Old Jul 10, 2005 | 05:48 PM
Plinko's Avatar
Go to your nearest performance shop and get your engine evaluated then talk with a guy that works there as to where you want gains in your powerband and he should know where to start as to knowing the inlets/outlets and all the other important things to building an engine. DO NOT RANDOMNLY BUY PIECES!!!! I can't stress this enough, if you do that, you will bottle up hp and flow unless by some miracle you get it all the right size. Talk to a professional is where I'm going with this. Or Michael Delaney on Team-integra.net.
Old Jul 10, 2005 | 09:27 PM
BuyImports2's Avatar
Default Re: (Plinko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plinko &raquo;</TD></TR><TR><TD CLASS="quote">Go to your nearest performance shop and get your engine evaluated then talk with a guy that works there as to where you want gains in your powerband and he should know where to start as to knowing the inlets/outlets and all the other important things to building an engine. DO NOT RANDOMNLY BUY PIECES!!!! I can't stress this enough, if you do that, you will bottle up hp and flow unless by some miracle you get it all the right size. Talk to a professional is where I'm going with this. Or Michael Delaney on Team-integra.net.</TD></TR></TABLE>
haha, thank you team-integra.
we need automatic responses for posts like this, so that we can just click a button instead of having to type it out for the millionth time.
murk, you have a lot of learning to do. go to team-integra.net, and read the articles, common topics, and search the posts. it is soooo much more complicated than simply purchasing an intake, or header, etc.
since your just starting out, you are going to need to first free up the airflow through your motor with things like an intake, exhaust, and header. make sure you read up on what type to buy. read up a lot.
oh yeah, did i mention you should read up on it? trust me, learn as much as you can, you'll be glad later on.
Old Jul 10, 2005 | 09:49 PM
Clipse1987's Avatar
Default Re: (BuyImports2)
It all depends on what route you are wanting to take but either way h/i/e is a given. After that I would recommend some kind of ecu, most likely hondata. I have had experience with non vtec integra's and there's not much you can do with simple bolt on's. You obviously need internals, and yes cam's would give you a noticable power gain but would also leave a empty space in your wallet. Good luck..........
Old Jul 10, 2005 | 11:06 PM
WH0R3nEF9's Avatar
Default Re: (Lewie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewie &raquo;</TD></TR><TR><TD CLASS="quote">Nitrous.
» Search Results
No question's a stupid question. We're all on here for a reason and this is his, so calm down and don't read threads you know you wont like.
Since you're new, check out the FAQ section and learn about the forum! Removing your your airbox will not gain power. Like the other guys said, start with intake, header and exhaust and go from there. Start reading and researching about your car and decide where you want to go from there. Good luck![
Old Jul 10, 2005 | 11:41 PM
shorto85's Avatar
Definitely start reading up on the articles over on Team-Integra. After that I you should be able to decide if you want to stay N/A or go FI.
Old Jul 11, 2005 | 02:17 AM
Jeezer's Avatar
put on a vtec head
Old Jul 11, 2005 | 07:00 AM
SargentNg's Avatar
Default Re: what are some cheap basic mods for a new integra (murk593)
Turbo gives you the best bang for the buck
Old Jul 11, 2005 | 07:08 AM
ok, he definetely said that he was looking for something INexpensive. that would almost definetely count out:
turbo
v-tec head
cams
Old Jul 11, 2005 | 07:29 AM
joek84's Avatar
type r rear sway bar. and altezzas
Old Jul 11, 2005 | 08:08 AM
Default Re: (joek84)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by joek84 &raquo;</TD></TR><TR><TD CLASS="quote">type r rear sway bar. and altezzas</TD></TR></TABLE>
wtf?
Old Jul 11, 2005 | 08:14 AM
Lewie's Avatar
Default Re: (1SiKTeG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SiKTeG &raquo;</TD></TR><TR><TD CLASS="quote">
No question's a stupid question. We're all on here for a reason and this is his, so calm down and don't read threads you know you wont like. [</TD></TR></TABLE>
I definitely don't need you to tell me to calm down.
And when this topic has been covered at least 59 times it becomes a stupid question. Other people helped him and I told him to search and showed him the results I got.
Old Jul 11, 2005 | 11:19 AM
TEG DRIVER's Avatar
Default Re: (Lewie)
spoonsirG yeah i hear you get what you pay for alot, but i don't have alot to dish out so idk. well anyways i got an automatic so not alot i think i can do but i plan on maybe a new intake manifold sometime in the future.
Old Jul 11, 2005 | 12:01 PM
TeaAddict's Avatar
CAI or short ram.
Old Jul 11, 2005 | 06:23 PM
TEG DRIVER's Avatar
Default Re: what are some cheap basic mods for a new integra (TeaAddict)
i ordered some NGK spark plugs and probaly get me some spark plug wires too
