what should I do?
Old Mar 5, 2004 | 06:56 PM
t . b o z's Avatar
Default what should I do?
Im not totally sure on what I want to do with my 2nd gen teg.
a.)turbo the LS
b.)LS/vtec
c.)swap with b18c1 or b16a2
Right now I have no clue on what I want to do. Maybe some of you guys can give me some advantages and disadvantages of each. Im thinking the ls turbo would be the cheapest way to go, maybe the fastest...but if I were to put a turbo on the vtec equipped motors there would probably be more. Opinions?
Old Mar 5, 2004 | 07:14 PM
Kendall's Avatar
First off, the LS bottom end can handle a bit more abuse than the VTEC bottom ends, so a turbo would be more fitting on one. I personally think this would be the best option for drag or highway racing, but not for road racing or autocross. If you just want to beat the local ricers, then I'd definately go with the turbo LS.
Old Mar 5, 2004 | 07:16 PM
t . b o z's Avatar
Ya, all I really need is a GOOD highway pickup and some strip credibility, I do plan to autoX it sometime just for the experience. I here its preety fun.
Old Mar 5, 2004 | 07:25 PM
threatcon13's Avatar
New User
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">First off, the LS bottom end can handle a bit more abuse than the VTEC bottom ends.</TD></TR></TABLE> Why do you say that? Because of the lower compression?
Old Mar 5, 2004 | 07:28 PM
Kendall's Avatar
Default Re: (Threatcon13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Threatcon13 &raquo;</TD></TR><TR><TD CLASS="quote"> Why do you say that? Because of the lower compression? </TD></TR></TABLE>
No, the rods are a bit beefier. Admittedly the sleeves are pretty much the same, but stock VTEC rods (regardless of engine tuning) don't seem to hold up very well past about 12 psi, while there are stock LS engines running as high as 15 psi.
Old Mar 5, 2004 | 07:32 PM
New User
No, the rods are a bit beefier. Admittedly the sleeves are pretty much the same, but stock VTEC rods (regardless of engine tuning) don't seem to hold up very well past about 12 psi, while there are stock LS engines running as high as 15 psi.</TD></TR></TABLE> I never knew that..thanks for the heads up
Old Mar 5, 2004 | 07:34 PM
t . b o z's Avatar
wow, didnt know that. Ive alwasy heard that the stock LS rods were kinda weak. I did know the LS likes being boosted...hell I have a friend thats running 17psi on stock internals stoopid tuned.
Old Mar 5, 2004 | 07:41 PM
t . b o z's Avatar
also, I think im gunna go with rota group n's in gunmetal metallic. Do they only offer a 15in in that wheel? You think that would look nice or should I look for a 16in wheel?
KMk51188
Jul 26, 2006 02:30 PM
calif_dave
11
Mar 2, 2005 08:05 PM
teg_love
Sep 21, 2004 10:11 AM
my ride
Apr 21, 2004 01:28 PM
teg969
May 14, 2003 05:14 PM
