What sensor is this?
Old Mar 13, 2004 | 05:51 PM
VNTEC's Avatar
B A N N E D
Default What sensor is this?
Argh, it came off my 91 LS OBD0... Now i have a 93 LS motor in it.. theres no place for it! where does it go? What does it do? And does anyone know where it goes on the newer obd1 LS motors?
Old Mar 13, 2004 | 07:23 PM
fullboostin's Avatar
Default Re: What sensor is this? (VNTEC)
could it be a crank sensor?
Old Mar 13, 2004 | 08:51 PM
riceball777's Avatar
its a coolent temp sensor for the fans
it senses the coolent tems in the engine and when the temp reaches a certain temp it will kick the fans on
i know this cuz this was what was causing my fans not to work and my thus making my car over heat
Old Mar 14, 2004 | 12:31 PM
deepgreengsr's Avatar
Default Re: What sensor is this? (riceball777)
he is right Crank angle pos sensors dont look anything like that, cept maybe the color, kinda
Old Mar 14, 2004 | 01:18 PM
SiR831's Avatar
Just like rice ball said. It's a fan switch but on the OBD1 motors it's located on the thermostat housing. Extend the (OBD0 harnnes) wires from the harness and connect them to the fan switch on the thermostat housing.
Old Mar 14, 2004 | 02:36 PM
SecretAznMan4u's Avatar
temp sensor
Old Mar 14, 2004 | 08:40 PM
VNTEC's Avatar
B A N N E D
Default Re: (SecretAznMan4u)
Where is the oil engine temperature sensor on the newer LS at?
Old Mar 14, 2004 | 11:10 PM
FastSS's Avatar
Default Re: (VNTEC)
I think its on the back somewhere near the oil filter...
Old Mar 15, 2004 | 10:37 AM
12secDC's Avatar
Default Re: (FastSS)
i'm not pretty quite sure in my point of view it's looks to me some kind a knock sensor i don't know i might be wrong!!!
Old Mar 15, 2004 | 10:59 AM
Quiks66's Avatar
Default Re: (12secDC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 12secDC &raquo;</TD></TR><TR><TD CLASS="quote">i'm not pretty quite sure in my point of view it's looks to me some kind a knock sensor i don't know i might be wrong!!!</TD></TR></TABLE>
Nope, no way that's knock sensor. It's most likely a coolant/temp sensor. What ECU are you using with your 93 LS motor? Any empty places in the block where it might go? If not, you either don't need the sensor with the newer motor or you will have to relocate it on the wiring harness. Keep looking
Old Mar 15, 2004 | 12:31 PM
Honda Hick's Avatar
I think it's been established that it is a coolant sensor . Yea, it is not in that location on OBD1 motors.
Old Mar 15, 2004 | 04:26 PM
VNTEC's Avatar
B A N N E D
Default Re: (Honda Hick)
I'm still using my 91 obd0 computer system because im going to be running turboedit. There is Nowhere that i know of that has a place for that sensor...
Jesse Santana
Jun 27, 2017 08:03 PM
fv8s
Jul 29, 2010 05:12 AM
black picture
Aug 7, 2009 04:53 AM
Simmerman
12
Sep 18, 2007 07:05 PM
VNTEC
Mar 15, 2004 04:50 PM
