What is this part called ?
The distributor base. Yes you can remove it, but i would recommend scoring or punching a reference mark so that you can install it in the same orientation it came out - that way you won't have to fiddle with a timing light.
Don't touch any of the parts inside other than the coil or ignitor as they are the only internal components that are removable without special equipment. You don't want to screw up a $410 distributor base.
Just remove the 3 bolts holding the base to the cylinder head and separate the plug(s).
mshields4129
May 23, 2012 12:57 AM
