What lugnuts are you using?
Old Apr 23, 2002 | 02:23 PM
Rory Breaker's Avatar
Default What lugnuts are you using?
I may as well get a new set as it looks as if a would-be thief tried to make off with my wheels unsuccessfully, but snagged a couple lugnuts before he got around to the lock
Kyokugen? I've heard they strip VERY easily. The Gorillas on JCWhitney?
I'd like some small diameter so they fit on my wheel. What are you using?
Old Apr 23, 2002 | 03:31 PM
GSRrR's Avatar
Default Re: What lugnuts are you using? (newgsrdriver)
The Gorillas are not small enough? I just ordered a set but I did not get them yet. I hope they fit my 16in C8. My McGard key would not fit into the holes.
Old Apr 23, 2002 | 03:46 PM
GSRaCeRbOI's Avatar
damn i guess theieves are that stupid all around (i live in CA).. the same thing happened to me a while ago.. they took off 2 lug nuts before they realized I had wheel locks... wtf? they chucked the lug nuts into my window tho... i had mugen lugs.. not sure what brand the 2 I bought to replace the stolen ones were....
Old Apr 23, 2002 | 04:08 PM
SSBlueDC2's Avatar
I just got some Kyokugen lugnuts, but I haven't put them on yet. I'll let you know if they strip easily after I put them on.
Old Apr 23, 2002 | 04:09 PM
SlyGSR's Avatar
Default Re: What lugnuts are you using? (GSRaCeRbOI)
last week in the early hours of the morning my alarm went off and went to check my car right away and didn't see anything special UNTIL I came back home that night from work to find the lugnuts on my passenger side gsr rims where gone!!! wtf? somebody has tools to take these off!!! what's the best lugnuts on the market? I'm putting two lugnuts per wheel and even 4 lugnuts per wheel if need be
SlyGSR
Old Apr 23, 2002 | 04:29 PM
neo1z's Avatar
Default Re: What lugnuts are you using? (SlyGSR)
im using kyokugens as well -- didnt have any problem with stripping
Old Apr 23, 2002 | 04:33 PM
speedymon's Avatar
Default Re: What lugnuts are you using? (neo1z)
Same here.
Old Apr 23, 2002 | 05:46 PM
Default Re: What lugnuts are you using? (GSRrR)
The Gorillas are small enough, I believe.
I heard the key is the part that strips easily...isnt it 7-sided or some garbage?
Old Apr 23, 2002 | 05:51 PM
dubster99's Avatar
The problem people have with stripping kyokugens is when they don't use the torque spec recommended by kyokugen. It is not the same as stock. It's the key that strips and breaks.
Old Apr 23, 2002 | 05:55 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What lugnuts are you using? (dubster99)
I hope they don't suggest using a lower torque than specified by Honda to hold the wheels on. I got a set of McGard locks from the stealership, and none too soon, a week later I found 3 lugs gone on one wheel and only the lock holding it on. Luckily I had 4 extra lugs from installing the locks, but now I only have one extra.
lilvader
Dec 17, 2017 08:32 PM
JDMB20TDA
10
Apr 7, 2011 09:20 AM
GagnarTheUnruly
Dec 5, 2009 04:00 PM
Knestis
Dec 4, 2005 07:10 PM
xunkn0vvnx
Oct 6, 2002 09:25 PM
