What to do next??
Old Sep 7, 2010 | 06:32 PM
ninja95gsr's Avatar
Default What to do next??
Picked up a decent 95 gsr for $2200 204k engine pulls strong doenst leak/burn oil.
Some things already installed
Skunk2 Camber kit
Tokico shocks
Eibach Springs
17" Excel rims black with nexen n5000 205/40
halo headlights
aem cold air with bypass
Hanabi?? exhaust
since ive had it ive (3 weeks):
Replaced the passenger door handle (broken)
Replaced the Drivers side door hinges (saggin)
Fixed the Center Vents and controls (was broken into before i got it and hanging loose)
Replaced timing belt, tensioner, water pump and crank pulley ( I broke the stock pulley trying to remove it, got a shiny red OBX-R underdrive pulley)
Replaced stock Torque Mounts with Avid Racing Torque Mounts
Replaced both door seals
Changed my tail lights to black ones (stock ones for sale pm me)
Replaced my valve cover with a red ITR valve cover and Carbon Fiber Wire cover
Replace Door Panels because leather was coming off
Put some screws in the front bumper to reattach it to the fenders and front frame
rewired my halo headlights (crappy wiring job, drivers side halo didnt work)
checked the plugs Perfect!
Minor problems still to fix
check wiring on drivers side window controls (cant roll down passenger side all of a sudden)
Fix the sunroof (wont open or close without assistance)
sell my big black 17" rims for some gold 15" rims
check the compression
pics
Shopping List
Turbo Kit
Skunk2 black manifold
skunk2 black 68mm tb
skunk2 complete valve train
skunk2 pro1+cams and cam gears
skunk2 valves
skunk2 rr exhaust
skunk2 pro c coilovers
cp pistons 84mm bore 9.7:1 comp
aftermarket ls rods
ls crank
sleeves
itr front end conversion
flat black paint
15" gold rims
drilled slotted rotors
anyways...i have been studying up on installing turbos and since i have never done that install before, i would like to learn by doing. but im not sure if i should push out a turbo install to work on the engine first. Should i go ahead and buy/install a turbo or teardown and rebuild the head/block (new pistons, rods, sleeves, valve train, cams, intake mani). My goal is to eventually get to 20+lbs of boost (too many v8s around i live 2mins from corvette plant and museum) but i want to learn everything i can. if i am to go the turbo route, where can i pickup a nice complete kit (im scared of ebay kits)? any advice/opinions would be great
Old Sep 7, 2010 | 08:38 PM
dntnedvtec's Avatar
Default Re: What to do next??
OKAY, I have never owned a turbo car, But I think I have enough knowledge to help you out. +20lbs Boost is asking for a rebuild. Full-Race makes kits, But prepared to spend big dollars but I hear they are worth it. Peak-boost is another. I have heard good and bad from ebay turbo kits. More bad than good, but some guys are just lucky. Go to the forced induction Forum here. You will learn a lot there.
Old Sep 8, 2010 | 12:22 AM
chewyv's Avatar
pm4nudes
Add body work to list.
Old Sep 10, 2010 | 10:53 AM
ninja95gsr's Avatar
I will keep studying.
noted
crucialDc2
Jun 10, 2011 07:38 PM
Spoon84
Oct 21, 2010 05:58 PM
EvenStar
Jun 27, 2008 07:45 PM
Rikaro
Mar 19, 2008 12:13 AM
ITR_1211
Jul 12, 2002 09:19 AM
