what to do next
well i drive a 94 ls with a 00 ls swap i have intake and i have headers and exhaust on the way what should i do next get a tune or what im kind of new to the car world so i dont really know what to get help me out her
well I agree with the suspension thing, but as to whatever is next, we need to know what kinda goals you want for your car. Do you want speed? if so, a turbo kit would compliment that b18b very nicely. Do you just want it to look nice? if thats the case, definately some rims and tires. And if you want it to handle a lot better, upgrade the suspension.. Sways, maybe some traction bars to eliminate wheel hop..
we just need to know your goals
welcome to the car world.
i want to keep that oem look but little lowered would be nice but i want speed to but i dont really want a turbo i want as much hp as i can get with no turbo
From: Dont say my car is topless say the titties is out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94-integra-ls »</TD></TR><TR><TD CLASS="quote">i want to keep that oem look but little lowered would be nice but i want speed to but i dont really want a turbo i want as much hp as i can get with no turbo</TD></TR></TABLE>
Maybe an Ls-Vtec conversion. If you want to keep it an Ls though, maybe do internals with a valvetrain upgrade and some head work.
id suggest getting the koni/gc combo for suspension, maybe some rota wheels just because they look nice and are pretty cheap. Then you'll have to start doing internal work.. do stuff to up the compression a little bit. Maybe get some Type R cams.. And are you familiar or ever heard of an lsvtec? Its kinda costly but itll help your ls engine out quite a bit. do a search on that.
if you want speed/power without a turbo then you gotta motor work, I would start with throttle body, intake man., injectors, then do head work or lsvtec, valve job, cams, springs, port/polish. ur lookin at big money with all that though and its not gonna give you nearly the gains that a turbo would.
remember this: power = money, if you dont want to spend the money you dont power that bad. I only say that cuz every noob I talk to ask's me "how can I make my car way fast with like 200 bucks" uhh.... you cant.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg racer 877 »</TD></TR><TR><TD CLASS="quote">I would start with throttle body, intake man., injectors, then do head work or lsvtec, valve job, cams, springs, port/polish</TD></TR></TABLE>
Throttlebody, intake manifold, and injectors are pretty much going to do absolutely nothing on an otherwise stock engine. The intake manifold might make a noticable but small difference but there's a lot better things you can spend that money on instead. For power I would suggest starting out with cams and a tune, with Uberdata if you can.
*Edit - you can search for 'Uberdata' and find a ton of info about it if you're wondering what it is
yea ill do some looking into it guys and i have heard of the ls/vtec but i read if you didn't know what you were doing then you could expletive something up bad but ill look into some type r cams and a good tune and i know you cant get any power for 200 dollars im not that stupid im willing to spend some money to make my car fast but might take a while to get some of this stuff what kind of pistons and rods would you guys recommend also
yea I know an im and tb arent gonna help u on a stock motor, thats why I said valve job, cams, ext. and it would help alot on a modified head, guess i shoulda said it in a different order.
PinkMaggit
Jul 30, 2006 03:58 PM
