What is this for
Old Jun 8, 2014 | 09:07 PM
Hughie1987's Avatar
Default What is this for
Not sure what this goes to but when I bought my DA last march I noticed it and havent found any listing of what it is used for, I have a 90 GS btw.
Old Jun 8, 2014 | 09:31 PM
h22aEJ1's Avatar
Default Re: What is this for
Is this pic taken on driver or passenger side ?
Old Jun 9, 2014 | 08:26 AM
Hughie1987's Avatar
passenger side of the car
Old Jun 9, 2014 | 06:02 PM
fcm's Avatar
fcm
Old Fart
OBD plug. 94
Old Jun 9, 2014 | 08:35 PM
Hughie1987's Avatar
really even tho my car is ODB0? I can turn the key to on and watch the ecu blink for engine codes without the pin method
Old Jun 10, 2014 | 04:40 PM
fcm's Avatar
fcm
Old Fart
Better known as the Service Check Connector. 94
Old Jun 10, 2014 | 04:58 PM
TheRealTegger's Avatar
The pre-'92 DA does NOT use the Service Check connector for reading ECU error codes.
The pre-'92 DA uses the Service Check Connector only for locking ignition-timing down to base before setting distributor position.
Old Jun 10, 2014 | 10:52 PM
Hughie1987's Avatar
thats cool to finally know where do i get one of those and info on how to use it haha
Old Jun 11, 2014 | 03:44 AM
Get WHAT? You don't need anything for reading codes on your car.
Old Jun 11, 2014 | 04:21 AM
m4xwellmurd3r's Avatar
You need part number 525881/72377
Simply unfold the device and insert it into the service connector. Start the car and set the base ignition timing using a timing light
Old Jun 11, 2014 | 07:05 AM
Or you can just use an opened paper clip. That's all I ever used for 22 years.
Old Jun 11, 2014 | 07:31 AM
Hughie1987's Avatar
Tegger, I was obviously talking about using it for timing not for reading the codes I already said I knew about counting the light flashes...
Old Jun 11, 2014 | 08:31 AM
I was talking only about shorting the Service Check connector, regardless of any reason why you'd do that.
You do not need any special tool to short the connector, even though one is available. All you need is a paper clip.
Old Jun 11, 2014 | 09:31 AM
Google the part number
Old Jun 11, 2014 | 10:12 AM
I've been had! I never actually looked it up, not suspecting you might have been pulling a joke!
sageuvagony
Aug 11, 2008 03:06 PM
af97civic
Sep 8, 2003 03:54 PM
Caveman74
Mar 16, 2003 03:07 PM
gsrhatch530
Apr 18, 2002 09:41 AM
