WET ENGINE
Old Nov 4, 2004 | 09:17 AM
Kaisar's Avatar
Default WET ENGINE
Before I go out and spend unnecessary money, maybe the forum can help me out.
This past weekend, I ran into a nice amount of water. It went in through the intake and flooded the engine. The mechanic says the engine is done, that i need to purchase another. By the way, I have a 97 Integra Ls. I believe he is over quoting me on the engines, but is there anything I can do to save that engine?
All comments would greatly be appreciated
Kaisar
Burn rubber, not your soul!!!
Old Nov 4, 2004 | 09:57 AM
robGSR's Avatar
Default Re: WET ENGINE (Kaisar)
you will need to take everything apart and see how is the inside, water is really bad just remember that water can't be compressed so maybe the rods took the hit, did you turn the car off at that moment? or the car turned off by itself?, or you just keep driving the car?
Old Nov 4, 2004 | 10:18 AM
Kaisar's Avatar
Default Re: WET ENGINE (robGSR)
I drove it just to the parking space which was about 12 yards from the water.
Old Nov 4, 2004 | 01:42 PM
robGSR's Avatar
for be honest with you man don't waste your time take the engine apart see what is in there don't even try to turn the engine on.
Old Nov 4, 2004 | 01:46 PM
Atheist's Avatar
Sucking air in changes the pressure so much you usually twist rods and crack cyl walls. I would say pull it apart and see if the sleevs are ok.
Old Nov 4, 2004 | 01:58 PM
JET_dC4's Avatar
Default Re: (Atheist)
pull the plugs and turn it over, if any water shoots out the top your usually in a bad situation, but that will help to get some of the water out. drain the oil, check the consistancy of the oil.
ps: i am drunk, hope this helps
tbonez
Honda Civic (2006 - 2015)
Dec 7, 2010 09:44 AM
guero2517
25
Apr 2, 2004 12:21 PM
SkylineGTR
Feb 5, 2004 04:45 PM
MikelH
Aug 24, 2003 10:30 AM
SMC Integra
Aug 11, 2003 01:28 PM
