Weird Interior Electrical Issue
The other day I noticed my interior lights aren't working, along with the chimes for the open door or light being on. So I played around with it and found that if you flip the switch to the overhead light (aft of sun roof) to the "on" or "off" postion the door ajar light comes on in the dash. If you have the overhead light on the "door open on" postion the door open light goes away, unless you turn on either one or both the map lights (right under the mirror).
Any one else have this problem. The fuses seem to been fine, but I will check them again to make sure.... Any info will be greatly appreciated!
Most dash harness grounds on Honda/Acura are found low on drivers "A" pillar, but find a ground location schematic for your car to make sure you get them all.94
N1Accord72
Feb 22, 2017 05:44 AM
